Prius c 2014 A/C problem
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Sayyaf, Feb 26, 2021.
  1. Sayyaf
    Sayyaf New Member
    Jordan
    2014 Prius c
    Hello
    My prius c 2014 when i turn on heat air , the a/c compressor work even when the A/C button turned off , and hot air coming from left side good but on right side not hot . What’s the problem ?
  2. Sonic_TH
    Sonic_TH Active Member
    574
    96
    Puerto Rico
    2016 Prius c
    Looks like a door that controls the flow of the air might be stuck, try by disconnecting the 12v battery for a few minutes and connecting it back on, then turn on the A/C and on max cold, see if it gets fixed, something similar happened to mine but doing this fixed it.
  3. Sayyaf
    Sayyaf New Member
    Jordan
    2014 Prius c
    I do that , the a/c button fixed but the hot air still have the same problem
  4. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    This post may give you any clues on how to proceed. It has to be some kind of bad motor/actuator/door that controls airflow. Heat is always produced of course there is typically a damper that shuts off the flow from the hot section when you select max cold. It is interesting that heat is flowing on only one side if I understand what you wrote correctly. I see one other post with the same problem but no solution, but most cars I've seen without a dual zone system (i.e., both driver and passenger have HVAC controls) will control the temp before the ducts split off to the vents on each side.
  5. Sayyaf
    Sayyaf New Member
    Jordan
    2014 Prius c
    Yes , I think it’s a bad motor/actuator/door that controls airflow , because today we just cleaned the water radiator and it was clear already, so I’m sure it’s a door not working
  6. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    Since I don't have a service manual, just looking at the parts diagrams is leaving me clueless how you could get different temps from each side. Here are the ducts which would attach to it.
    https://parts.olathetoyota.com/v-2014-toyota-prius-c--three--1-5l-l4-electric-gas/body--ducts
    Here are the blower parts
    https://parts.olathetoyota.com/v-2014-toyota-prius-c--three--1-5l-l4-electric-gas/hvac--blower-motor-and-fan
    It appears that servo (#5) should control which vents but maybe it is the temp servo. I'd try to listen carefully for the servos moving while you select different vents and temperatures. I'm not sure if you'd be able to see anything moving up under the dash.
    It sounds like #5 is major pain to change, but some people have had luck doing a power reset for stuck servos. See this thread. Good luck!
  7. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    topshot likes this.
  8. Sayyaf
    Sayyaf New Member
    Jordan
    2014 Prius c
    Yes that’s right, I’m trying to find way to access that’s part without remove front tabloid , that was helpful thanks guys
