Prius c 2015 doesn’t spin the engine
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Misnik777, Jun 15, 2024.
  1. Misnik777
    Misnik777 New Member
    North Miami Beach
    Just bought from auction. Prius C 2015 doesn’t start engine. Electro motor tries to start the engine, make a scratch sound, but crankshaft doesn’t even spin. How to fix? What to change? Thanks
  2. Leadfoot J. McCoalroller
    7,130
    6,677
    Pennsylvania
    2018 Prius c
    Usually that means the hybrid battery (the big one) has been discharged below the lower limit.
    You can attempt to recharge it yourself- if you are okay working with high voltage and understand how to modify electronics.
    If you're going to get anywhere with that car, start by getting a diagnostic scanner that can talk to each and every system in there. I recommend the Autel AP2500E, and I have heard good things about the very similar model AP200.
    This link will tell you how to get a subscription to the actual factory repair manual.
  3. ChapmanF
    15,401
    If you hear the sound of MG1 spinning (and you're sure that's the sound you're hearing, say if you have a scan tool showing live data and it shows >0 MG1 RPM then) but the crankshaft doesn't move when MG1 does, something is busted in the transmission or bellhousing.
