Prius C 2016 HVAC actuator Location
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by I_commute_to_work, Nov 7, 2021.
  1. I_commute_to_work
    I_commute_to_work Junior Member
    Southern California
    2015 Prius c
    My 2016 Prius C Three blows AC blows air in the wrong vents.
    It seems the HVAC door blend actuator has gone bad.
    I've been trying to look where exactly it is located but no luck so far. Also anyone knows the part number?
    Thanks.
  2. Sonic_TH
    Sonic_TH Active Member
    545
    86
    Puerto Rico
    Try by disconnecting the 12v battery for a few minutes. I think that if you want to access that door you have to remove the entire dash.
  3. ChapmanF
    15,448
    I would say it sounds like the air outlet actuator has gone bad. The blend actuator is the one that makes the air warmer or cooler.
    I_commute_to_work likes this.
  4. I_commute_to_work
    Southern California
    2015 Prius c
    UPDATE
    It fixed itself, broke again, and today somehow it's working fine again.
    I think it's a programming thing because I usually haul azz when pressing the buttons to switch vent output.
    I've been taking it slowly now when I press the buttons and so far so good. Must admit I have PTSD when I interact with the AC controls now.
  5. topshot
    topshot Member
    142
    56
    Midwest
    2015 Prius c
    It sounds like either the output actuator per ChapmanF or the switch itself is on its way out. It seems the switch on the c has had issues of getting stuck in OFF for the some users so maybe it isn't that robust. Is there a reason why you keep changing vents instead of keeping it in AUTO mode?
  6. I_commute_to_work
    Southern California
    2015 Prius c
    Mainly for windshield defog. I'm trying to leave it in auto from now on, and be gentle if adjustments are needed.
    So my suspicion is that it's not mechanical issue but a software/logic problem somewhere, only time will tell.
  7. topshot
    topshot Member
    142
    56
    Midwest
    2015 Prius c
    Highly doubt that since it affects only your car and not the thousands of others from 2015 on the road (I have the same vehicle). It is a mechanical or electrical issue that is currently intermittent.
