prius c 2017:FOG LIGHT CONNECTION
Discussion in 'Prius c Main Forum' started by Yash Mauritius, Aug 22, 2023.
  1. Yash Mauritius
    Yash Mauritius New Member
    Mauritius
    2017 Aqua
    PRIUS C 2017: connected new aftermarket fog lights to FACTORY HARNESS but cant located the FACTORY relay,switch,fuse for it. HELP plz.
  2. Sonic_TH
    Sonic_TH Active Member
    545
    86
    Puerto Rico
    If the car did not came with fog lights from the factory, even if the wire harness is there i do not think the fuse and relays needed for the fog lights to work were installed at the factory in Japan.
