Prius c aftermarket headlights/tail lights
Discussion in 'Prius c Accessories and Modifications' started by J05hua__, May 17, 2023.
  1. J05hua__
    J05hua__ New Member
    Trinidad
    2014 Aqua
    I'm looking for a pair of good quality and reasonably priced aftermarket headlights. Any suggestions?
  2. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Depo brand are the best aftermarket headlights I've seen and they are usually half the price of Toyota's part. I don't think Depo sells direct, but they are sold through all the major autopart sites and chains.
    Example (not an endorsement)
    J05hua__ likes this.
  3. J05hua__
    J05hua__ New Member
    Trinidad
    2014 Aqua
    They sell the whole assembly?
  4. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    I can't recall if they arrive populated with bulbs, and you'll need to re-use your fasteners but yeah, it's the whole sealed module.
  5. J05hua__
    J05hua__ New Member
    Trinidad
    2014 Aqua
    Ahh okay cool. I’m sorry for the misunderstanding but I meant aftermarket lights along the lines of let’s say the valenti brand. Ones with drl.
  6. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Gotcha, no worries. I know the sort of item you want but am not aware of any availability for Prius c, sorry.
    Best of luck!
  7. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Just noticed you're posting from Trinidad- if I'm not mistaken that means you drive on the left, which means you could theoretically use JDM assemblies without having to modify them for the low-beam offset.
    That might open things up for you a bit.
  8. J05hua__
    J05hua__ New Member
    Trinidad
    2014 Aqua
    Yes, that’s correct, but before I commit to one thing, I’d like to see if anyone has any recommendations.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    My recommendation is:
    IF the lights are working now........leave them ALONE.
    ADD some if you must but don't screw with the stock ones or you might end up with no lights at all.
