Prius c, BAFX OBII, Touchscan
Discussion in 'Prius c Technical Discussion' started by JPTuck, May 19, 2014.
  1. JPTuck
    JPTuck Member
    110
    29
    South Deerfield, Mass
    Just purchased the BAFX OBII for Android scanner to use with my Prius C and Touchscan app. Seems to only work intermittently-will connect for about 5 min then lose the connection and have to shut down and restart my Kindle Fire HDX and restart Touchscan for the scanner to be 'found' again and start sending info to the Kindle again. Anyone else tried this android based obd scanner and had any reasonable success with it paired with a tablet? Thx.
  2. JPTuck
    JPTuck Member
    110
    29
    Update - tried the obd2 scanner and the Kindle with my wife's Matrix - worked flawlessly in all aspects/menus of the scantouch software so am wondering if it has to do with the Prius itself?
  3. mark schofield
    mark schofield Junior Member
    works well with my nexus 5 android smartphone. and can switch same sensor to a tacoma using same phone no problem
