Prius C Engine warmup time
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mark2000, Aug 27, 2014.
  1. Mark2000
    Mark2000 Junior Member
    2014 Prius c
    Hello, all. I've had a 2014 Prius C II for three months now and have noticed that the combustion engine comes on with quite a bit of force when the car is turned on for awhile. I then stays on for two or so minutes revving itself away. This seems to kill my MPG numbers as I always start with between 9 and 18 by the time the engine calms down. Is this normal? Is there some way to limit it? I don't live in a particularly cold place (San Francisco hits lows of 50 at worst).
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    49,500
    for most pri, the ice starts within a few seconds of starting the car. it must warm up and stay warm for emissions purposes. otherwise, other than hvac, it's a nice blend of ice and electric to achieve record breaking mpg's. however, if you have a very short commute, you will suffer from warm up psychosis and never reach the mpg's you desire. they will still be higher than a similar size gasser tho.
  4. Mark2000
    2014 Prius c
    So how does the engine block heater work, exactly? Do you need to plug it into the wall right before you drive? How long does it have to be plugged before you can drive?
  5. bisco
    49,500
    they're great in cold country, but you're gonna offset your increased mpg's with increased electric bills.
  6. firstrival
    firstrival Member
    102
    There is nothing wrong. Don't worry about it.
