Prius C GPS - all greyed out
Discussion in 'Prius c Main Forum' started by UnSurreal, Apr 27, 2012.
  1. UnSurreal
    UnSurreal Junior Member
    38
    16
    Waterloo Ontario
    Hi guys,
    I'm trying to use my GPS and can't figure out how to get it active.
    It seems like it's all greyed out because it thinks I'm the driver, but a passenger can't even use it.
    I try to add a home address or new address and everything is greyed out, including the save button.
    Help? =) Thanks.
  2. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
  3. minglee012
    minglee012 New Member
    so cal
    The only way to operate navigation while in motion is to use voice button on steering wheel.
    Instructions:
    Press the voice button,
    wait for the beep, then you say "enter zip code",
    (it might respond with "cancel" the first time you say "enter zip code" but push voice button again and try 2nd time),
    the car will ask "say the zip code",
    wait for beep, then you say "90404" (or whatever zip code you want),
    the car will ask "select line number",
    wait for the beep, then you say "line 1", the car will say "line 1",
    wait 5 seconds and it will ask you "say the street name",
    wait for the beep, then you say "santa monica boulevard" (or whatever street you want),
    wait 5 seconds and it will ask you "say the street number",
    wait for the beep, then you say "8 0 1" (or whatever number you want),
    wait 5 seconds and it will ask you "do you want to start street guidance",
    wait for the beep, then you say "yes",
    wait 5 seconds and it will say "starting street guidance"
    note:
    if you get the wrong zip code then push voice button again and say "enter zip code"
    if you get the wrong street name then push voice button again and say "enter street name"
    if you get the wrong street number then push voice button again and say "enter street number"
    3 people like this.
