Prius C Hybrid Battery discontinued?
Discussion in 'Prius c Main Forum' started by Andrew Facchin, Jan 18, 2023.
  1. Andrew Facchin
    Andrew Facchin Junior Member
    25
    British Columbia
    What is everyone going to do once they can no longer get a new Hybrid Battery for the Prius C as I believe the last production year was 2019? Also, what did you all do to put in a regular starter car battery as the C battery is a little weak in my opinion...
  2. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    2019 was the last year they were imported into the USA. They kept making them for another two years, then they redesigned the body and the all-new version is currently for sale in the rest-of-the-world.
    Screen Shot 2023-01-18 at 6.57.48 AM.png Screen Shot 2023-01-18 at 6.58.01 AM.png
    (2023 model pictured)
    Given that the Prius c/Aqua was one of the top 5 most popular cars in Japan 2012-2017, and only somewhat less popular for the years after, I'm not especially worried about parts. They're going to make parts for these for a really long time.
    Even if they did discontinue the finished battery assembly itself, the actual battery modules inside the pack are exactly the same as the ones in the other Toyota hybrids of the same vintage. So you could use modules from other Priuseses, Camrys, Highlanders etc.
    While the c may not be very common in the USA, the global parts supply for these cars is about as good as it gets.
    Now as far as the 12v battery goes, you can get one at the dealer or generics from Batteries+bulbs stores, some Walmarts and autoparts stores. Look for size S34B20R. (Link goes to example at o'reilly)
    Note that 2017 & later c uses a different battery which is harder to find; dealer only for now.
    #2 Leadfoot J. McCoalroller, Jan 18, 2023
  3. farmecologist
    farmecologist Senior Member
    1,960
    1,799
    Southern MN
    Oh man..every time I see a picture of the new Prius Aqua, I want one!
    As for parts, the Prius C is pretty much a 'world car'...or was. Agree that finding parts won't be an issue.
    It wasn't any problem finding a 12V battery for our 2012 when I needed one. (y)
