prius c ICE and Hybrid radiator location
Discussion in 'Prius c Accessories and Modifications' started by Flying White Dutchman, Dec 25, 2013.
  1. Flying White Dutchman
    4,374
    313
    can not find any info about this
    is this the same like with the prius gen 2 or like the gen 3
    maybe even compleet different.
    i ask this for the grill blocking winter time
    with my prius gen 2 i do a upper grill for the ICE and part ( at lower temps also full ) lower block where the hybrid radiator is located
    with the Prius gen 3 you do the opposite..
  2. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    If you look under the hood the Inverter radiator is located on the bottom of the ICE radiator. You can follow the hoses.
  3. Flying White Dutchman
    4,374
    313
    a ok visually i dont see the radiotors its blocked from view but indeed if i follow the hoses then maybe .
    so you know for sure the lower part is for the HSD? like in the gen2 prius and opposite of the gen3 where its located at the top?
    thx!
