Prius C Lithium Upgrade Hands On
Discussion in 'Prius c Technical Discussion' started by PriusPilotSurfer, May 4, 2021.
  1. PriusPilotSurfer
    PriusPilotSurfer New Member
    Orange County
    Came across this very cool hands on video on a Lithium battery swap and EV test. This is not my video and wanted to share with you all tech people that may be looking into a NiMh alternative. Looks like the batteries will be available from projectlithium.com. Exciting to see this technology not only be more cost effective but provide more power and better overall efficiency. More mileage! Looks like I will be keeping my Prius for much longer!
    Pri3C likes this.
  2. AzusaPrius
    AzusaPrius Senior Member
    1,829
    811
    49,377
    this is going to keep prius on the road a lot longer which results in a better environment for all of us
    BobDaScotty and Pri3C like this.
  4. Pri3C
    Pri3C Active Member
    180
    127
    Midwest
    2014 Prius c
    70mph using only battery?!
    If my C needed a new hybrid battery this would be the most appealing option to me. The install looks very doable..just a ton of bolts to keep track of.
    Looking forward to reading more reports from early adopters, and I hope these packs prove to hold up well over the long term.
    BobDaScotty likes this.
  5. PriusPilotSurfer
    Orange County
    Thanks for the replies everyone! I'll keep updating as we learn more! 70mph is amazing!
    Pri3C likes this.
  6. BobDaScotty
    BobDaScotty Junior Member
    Wilmington, DE
    2016 Prius c
    Gobsmacking!
    I will look back every so often at your progress, this really is a gamechanger.
    Does the non OEM generate any annoying error codes or the dreaded yellow warning triangle?
  7. anas abu kaff
    anas abu kaff Junior Member
    jordan
    2015 Prius c
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    He did NOT do that with a C. The logic that handles the battery won't allow that.
  9. Pri3C
    Pri3C Active Member
    180
    127
    Midwest
    2014 Prius c
    Yeah, I can see they’re driving a bigger Prius, but it’s still an impressive result. I’m excited to see how these perform on all models.
