Prius C...no belts?
Discussion in 'Newbie Forum' started by maidenfan84, Apr 27, 2017.
  1. maidenfan84
    maidenfan84 Junior Member
    40
    16
    Michigan
    2016 Prius c
    So I just bought a new 2016 Prius C about two weeks ago and I've been trying to learn everything I can about the car. I understand that there's no starter, alternator, timing belt, or power steering pumps. But, is it also true that there's no belts of any kind that need replacing?
    LnG likes this.
    51,140
    true. everything has an electric motor. the previous generation had a serpentine belt for the water pump.
    pretty sweet, right?
    maidenfan84 and RCO like this.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    There is no 12 volt starter or 12 alternator, those are high voltage parts mostly handled by Motor/Generator1 and M/G2. The power steering is electric. There is a timing chain, but no belts. It will most likely last 1/3 million miles.
    is a overview of the electrical system of a Gen 2 (all Prius are similar)
    this treats the mechanical connections of the high voltage M/Gs and the engine.
    LnG, maidenfan84 and Raytheeagle like this.
  4. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    Ummm ... it does have seat-belts I hope (for your sakes)?
    David S.
  5. maidenfan84
    40
    16
    Michigan
    2016 Prius c
    Thanks for the great replies! It's just odd to think that it truly is a vehicle with almost literally only oil changes and tire rotations, nothing else needed. In a day and age where most cars become over complicated and need more attention than ever, this car goes the opposite by the "less is more" approach.
    RCO and bisco like this.
  6. bisco
    51,140
    yep, first 120,000 miles are on toyota.:)
    maidenfan84 likes this.
