Prius C No Start, No Gear Position Indicator on Dash
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by wojoxx98, Jan 26, 2022.
  1. wojoxx98
    wojoxx98 New Member
    Pennsylvania
    Hey all,
    I have a 2013 Prius C Two, 129k miles, that I just wrote out a check for the final payment last week. Today I was out running errands and I stopped for lunch. I turned the car off, but left the key turned to accessory as we were eating in the car and wanted to listen to the radio. The lights were turned off, as well as the heater. We were there for no longer than 30 minutes, and when I went to start the car nothing happened. The speedo came up, but the shift indicator never lit, and the info screen in the dash got really dim. The ready light never illuminated either. Slightly panicked, I shifted the car between park and drive a few times, turned the key and got nothing. Got out, pushed to make sure it was actually in park. After about a minute of this, I turned the key and it started like normal. This has never happened to me before and I feel like this is punishment for paying the car off. It’s been 100% reliable for the last 4 years and 55k miles. From other posts I’ve read it sounds like it’s a dying 12v battery, but no one else seemed to have the exact same problem as I did. I have no clue as to the age of the battery, but I haven’t replaced it since I got the car. I should note the temperature locally hasn’t been much over freezing for the last month, and I don’t believe it’s gotten over 20°F today. Thank you for any advice!
    49,492
    yes, it is likely the 12 volt. you can get a free test at most any auto parts store.
    since you purchased the car 4 years ago, it is likely original, and had a good life.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    It seems that no two cars exhibit exactly the same symptoms when the 12 V battery starts getting weak.
    Give your description of what you did and what happened........
    The odds are huge that you just need a new battery.
    Be sure the new one if fully charged before being used.
  4. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    I'd believe a dead 12v battery.
    Lucky for you the 2013 model uses a relatively easy-to-find battery. Good luck!
