Prius C one won’t shift out of park
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jenster, Jul 8, 2018.
  1. Jenster
    Jenster New Member
    Vermont
    2014 Prius c
    i can manually shift it out of park with the release button and then it switches gears fine but as soon as I put it in park again, it stays in Park. My brake lights work. My back up lights seem to be out. Do you think they are related?
    51,952
    maybe. can you test the 12 volt health?
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    A neutral safety switch malfunction could cause something like this. Not sure if that's your issue or not, but it sounds like either that switch, or your computer isn't sensing that the brake pedal is being depressed. It's engaging enough to trip the lights, but not the computer, perhaps.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Here's a long shot but, did you or anybody ever figure out the problem?
  5. kingnba6
    1,018
    242
    NY
    Turned out, it was the fuse that controls both the backup lights and shifter lock.
