prius c r15 rims
Discussion in 'Prius c Main Forum' started by rrmelgar, Jan 28, 2020.
  1. rrmelgar
    rrmelgar Junior Member
    Paterson
    hi wondering if this wheel will fit my prius c.. tire size matches 100% wondering if rim will fit.
    have local person selling set of 4 those are specs
  2. topshot
    topshot Member
    142
    56
    Midwest
    2015 Prius c
    The lug bolt diameter is correct (100 mm). The question is the hub diameter <, = or > the Prius c (54.1 mm). If larger you can get a spacer ring as shown in this thread. Obviously, smaller is a no go.
  3. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    It's local so it's worth a test fit of one.
    It really smells right, I'd go for it.
    Check the date code molded into the sidewall on those tires. Snow tires tend to lose a lot of grip after the 3rd or 4th year.
