Prius C Shift Lever Light
Discussion in 'Prius c Main Forum' started by Joshua Shay, Jul 1, 2018.
  1. Joshua Shay
    Joshua Shay New Member
    Los Angeles
    Hello all! I just bought a used 2012 Prius C One and realized that at night, when I turn the headlights on, the gear shift lever that says P-R-N-D-B does not light up. I was wondering if the Prius C gear shift lever lights up? Thank you!
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I'm fairly certain my C4 does. I'll check when I'm on my home tonight.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The bottom display that actually has PRNDB should light up; the shifter lever itself does NOT.
    dubit likes this.
  4. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I agree.
  5. Joshua Shay
    Los Angeles
    Mine definitely is not lighting up, any tips on how to fix it?
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Probably a bulb burned out, or a fuse.
  7. sam spade 2
    7,035
    2,788
    2017 Prius c
    I'm not with my C for a few days to test but it seems that I remember that the display only lights up when the headlights are turned ON.
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    He notes in the OP that his does not turn on when he turns the lights on.
    PCSpaceShip likes this.
  9. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    you can replace the bulb
    ztanos and dubit like this.
  10. WeyldFalcon
    WeyldFalcon Junior Member
    Amherst, MA
    did you ever figure this out? I am having the same issue. What model bulb do you need? any videos of how to access the bulb to replace it?
  11. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Mine is starting to be wonky. If I press the shift lever left too hard, the light goes out... but then when I press it again, same hardness, it will flicker and come back on.
    I probably have a loose terminal.
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    There is nothing to "figure out".
    The top of the shifter stalk itself does NOT light up. Is not supposed to.
    Thus, there is nothing to "fix".
  13. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Unless of course, they're referring to the P/R/N/D/B as mentioned in the first post before the shifter knob light bulb question.
  14. WeyldFalcon
    Amherst, MA
    @ztanos has the right idea. The P/R/N/D/B does not light up.
  15. WeyldFalcon
    Amherst, MA
    The strangest part is after about 9 months of not working last night it worked, but once again tonight it was not working again. That sounds like a loose wire/fuse more than a bulb to me.
  16. sam spade 2
    7,035
    2,788
    2017 Prius c
    True.
    But the "loose wire" could be inside the bulb or the bulb could be loose in the socket.
  17. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Mine does this. If I hit the shifter a little hard to the left it will turn the lights on or off. :D
  18. ShoesmithJ
    ShoesmithJ Junior Member
    24
    Pacific Northwest
    I am an original owner of a Prius C² 2012. I had the same issue starting at 80,000 miles. I'd hit the console and it would light up (less and less likely after a bit) and it was dimmer I noticed. I figured I'd pay up and find out what was going on and make sure nothing truly serious was going on. Turns out the bulb was burning (burnt) out. It's apparently a very hard bulb to access and you need specific tools to do it. My dealer said if I did the diagnostic it would be absorbed into the labor cost. The diagnostic was cheaper (at first) than the labor if I just had them replace the bulb. They ended up charging me less. I had the diagnostic and labor done with the bulb part cost for $139.74. NOTHING was loose. I just needed a new bulb.
    Here is the final write up with the part number for the bulb. I hope this helps. IMG_20181219_141647025~2.jpg
    ztanos likes this.
  19. ShoesmithJ
    24
    Pacific Northwest
    Bulb part: 9098111014
    9098111014 - Bulb - Genuine Toyota Part
  20. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    $140 to change a bulb? Wow! Us at the shop would probably do it for $50, maybe less to possibly have customer come back in the future ;)
    9098111014 is a T5 wedge bulb (a little smaller than 168/194 bulb). T5 wedge bulbs are super cheap on ebay, maybe $3 for a 10 pack... See attached image.
