Prius C Started on it's own
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Ms Crossq, Jan 31, 2016.
  1. Ms Crossq
    Ms Crossq New Member
    Raleigh
    2015 Prius c
    About 11:45 pm, I heard the beep of my car. When I check to see what happened, I was VERY surprised to see that the car was RUNNING !!
    Why??
  2. Dion Kraft
    Dion Kraft Member
    272
    79
    Washington, UT
    Are you sure you shut it off earlier?
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Yeah, I would guess that the car wasn't shutdown earlier.
  4. Ms Crossq
    Raleigh
    2015 Prius c
    Very sure ! It's been turned off with the key since 3 pm this afternoon
    The model I have doesn't have push button start; you need the key to start the car.
    #4 Ms Crossq, Jan 31, 2016
  5. 48mpg
    48mpg Member
    193
    46
    florida
    I
    hope its parked outside, the exhaust fumes will kill you if its in an attached garage, disconnect the 12 volt battery if you leave it inside
  6. Dion Kraft
    Dion Kraft Member
    272
    79
    Washington, UT
    Observe it again and make sure the garage door is open and your headed in so the exhaust is pointing out toward the garage door.
    That or as others have suggested leave it outside for this test.
  7. bisco
    49,504
    christine?:sneaky:
    or maybe you got a gm ignition switch.:p
  8. Mendel Leisk
    38,733
    That was a good yarn.
  9. ETC(SS)
    6,556
    Next time it happens, take a cell phone vid and THEN start the warranty dance.
    Unless you have remote start, there aren't many other ways for the vehicle to be running without the key in the ignition.
    You may also consider locking the car inside the garage (you'd be surprised how many people don't) and leave the door cracked for positive ventilation.
    Now is a good time to check and see if you have CO detectors! Note the pluralization!!
    If you don't, get them immediately, and not just for 'Christine.'
    Good Luck!
  10. orenji
    orenji Senior Member
    5,884
    3,486
    Maybe leave a GoPro running inside the car for proof.....for the dealer to see it actually happen.
  11. InPriusLove
    InPriusLove Member
    165
    40
    California, US
    2015 Prius c
    The beep of the car indicates it was unlocked by some action by someone. Using a metallic key requires fewer start steps than a push button smart key. It takes a moment to start a car with a key. You leave some details out. When you approached the car, was it running without a key in the ignition? If it could run without a key in the ignition then it could have been on for eight hours. Not having a key in the ignition may be a non issue with the car although I hadn't heard of it. If you were given the key slot of a key system and the mechanics of a smart key system, then merely taking the key out may have little effect on turning off the car. Bring it to the dealer without any testing and get them to look. They may need to change your ignition innards.
  12. bisco
    49,504
    do you live near a military installation?
