Prius C upgrade headlights
Discussion in 'Prius c Main Forum' started by Ericbecky7, Mar 14, 2017.
  1. Ericbecky7
    Ericbecky7 New Member
    Arkansas
    Four Touring
    My 2012 Prius C headlights on Dim very hard to see thinking about Installing a LED light bar in it or maybe I'll grab some better upgraded headlight anybody have any ideas thank you
    49,490
    welcome!
    no idea, but perhaps @ericbecky can be of help. all the best!
    Raytheeagle likes this.
  3. AliIzad
    AliIzad Member
    170
    72
    Southern California
    In my opinion your best option is an HID kit. I installed one in my 2012 C back in 2013 with a huge improvement and no issues at all. I recommend a complete kit from either Xenon Supply or The Retrofit Source(TRS). Both companies offer a high quality kit, a good warranty, and everything you need in one simple to install kit. All you need is the complete kit they offer; you won't need any additional wire harness or anything else. They are not the cheapest, but seem to work the best and be safe. These kits install in less than an hour.
    As for the Kelvin rating of the kit, if you go Xenon Supply I recommend their 6000k kit, and if you choose TRS, I would get their 5000k. They are both very similar and make a huge improvement over stock. Also, I would avoid the majority of the cheap kits offered on eBay and Amazon. I have had only bad experiences on my other vehicles using the cheap kits; others may know of less expensive kits that work well. Good luck.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Alter ego, much like @brisco :whistle:?
  5. firstrival
    firstrival Member
    102
    I have been using the Xenon Supply 6000K kit for over 4 years. Works great.
  6. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Make sure you check your states laws after market HID kits are illegal in Virginia and I was made to remove mine to pass the safety inspection.
  7. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I modified H9 bulbs to fit where the H11s go. The H9 has a tab inside its connector that you'll need to cut off with a nice sharp pair of wire cutters or similar.
    The stock H11 has 55 watts. and puts out 900-1400 lumens. It has a design life of 270 hours, and a painted tip.
    The H9 has 65 watts, puts out 1760-2240 lumens, has a design life of 240 hours, and a clear tip.
    As you can see the H9 is significantly brighter, while only using 10 watts more than the stock bulb. I've been running with these for 3 years without issue. Since our cars have projector lenses - the non-painted tip of the H9 does not matter - the optics provide the cutoff to not blind oncoming traffic.
    The advantage of this setup is the simplicity, it looks totally stock, so no getting flashed for HID retrofits, doesn't need extra wiring or ballasts. I also prefer the halogen color temperature - I find the blue light of LEDs and HIDs to really obscure the view in the snow and fog when compared to yellower halogen bulbs.
    When I got my car I found that the headlights were aimed very poorly from the factory. I re-aimed them on a wall with horizontal lines (bricks!) and drove to see my adjustments. The highway I drive on has a barrier in the middle, so I aligned my beam cutoff to be parallel to the top of the wall, adjusting a bit each day until it was perfect.
  8. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Would you mind explaining the process for adjusting the headlights. I have read several threads on how it is done and there seems to be some mixed info. I appreciate it.
  9. Robbief
    Robbief New Member
    Augusta
    2015 Prius c
    Kinda off topic but on topic at the same time, but has anyone used the jdm rally yellow osram halogen bulbs they sell for the aqua/Prius I wanna say toms pushes em as well. If so are they brighter than the ones equipped?
