prius c wiring diagram?
Discussion in 'Prius c Audio and Electronics' started by evil03, Apr 25, 2015.
  1. evil03
    evil03 Junior Member
    any one here can help me out?
    i am specifically looking for the speed sender wire location and color of the cable that send the info to the speedo
  2. ChapmanF
    15,622
    Your c wiring diagram manual is at techinfo.toyota.com with the rest of your service manuals. Since the car has several sensors that can be used to determine speed (wheel speed sensors at each wheel and a resolver in MG2), it's possible your speed display gets the info by CANBUS messages from other ECUs that have it ... in older models I think the combo meter itself would then synthesize the speed pulse signal that was used by, e.g., the nav unit, but I don't know if that's still how they do it, which is why your best bet is probably to check the manuals.
    -Chap
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Now only if somebody had a free copy.
  4. PriusInParadise
    180
    91
    Hawaii
    On the North American spec Prius c, there is no discrete speed signal to the combination meter.
    As Chap stated above, vehicle speed data is communicated via CAN.
  5. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    I just started a 2 year subscription for $12.95 with Alldatadiy. It's not the same as the Toyota's, but it's not nearly as expensive either.
  6. evil03
    can anyone confirm that the PC vss data is provide by CAN
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It was already confirmed by priusinparadise above. Go with that, he knows his stuff.
  8. evil03
    good to know thank you guys....
    i only wanted to know so i can correct my speedo since i am using different tire specs
