prius c /yaris hsd scangauge codes ( inverter etc convert from torqapp? )
Discussion in 'Prius c Technical Discussion' started by Flying White Dutchman, Dec 16, 2013.
  1. Flying White Dutchman
    4,374
    313
    i wonder if there are any new codes to find
    like did anyone find the inverter temps settigs for the scangauge
    i know for the torqapp there are the inverter temps so can anyone translate them into scangauge II xgauge codes?
  2. Flying White Dutchman
    4,374
    313
    i think i have found them
    it was in the prius c scangauge topic and i dit not see it in the list the first time.
    did anyone test this already? they work also on a yaris?
    MG1 temperature 07E22161 02EA04610561 2808 00010001FFD8 tM1 degC
    MG1 temperature after IG-ON 07E22161 02EA04610561 3008 00010001FFD8 tm1 degC
    MG1 temperature Max 07E22161 02EA04610561 3808 00010001FFD8 TM1 degC
    MG1 revolution 07E22161 02EA04610561 4010 000100018000 M1R RPM
    MG2 temperature 07E22162 02EA04610562 2808 00010001FFD8 tM2 degC
    MG2 temperature after IG-ON 07E22162 02EA04610562 3008 00010001FFD8 tm2 degC
    MG2 temperature Max 07E22162 02EA04610562 3808 00010001FFD8 TM2 degC
