Prius canbus message's
Discussion in 'Gen 2 Prius Technical Discussion' started by Flying White Dutchman, Mar 16, 2008.
  1. Flying White Dutchman
    4,374
    313
    i got the elmscan 5 and trying to get some usable info from the canbus
    using windows hyper terminal i got a succefull connection and some response from the car.
    only do not now what to do with the following information
    send : 03CB ( battery )
    and get :
    7EA 03 7F 03 12
    7E8 03 7F 03 12
    7EB 03 7F 03 12
    i translate this to decimals and get
    7EA = 2026
    03 = 3
    7f = 127
    03 = 3
    12 = 18
    maybe the 7EA is the prius ECU ident?
    sending al using attilla fas excel sheet
  2. Flying White Dutchman
    4,374
    313
    >03cb
    7EB 03 7F CB 11 00 00 00 00
    7E8 03 7F CB 11 00 00 00 00
    7EA 03 7F CB 11 00 00 00 00
    ok i adjusted the read out from the elmscan to show all
    i got 3 ecu's all the same message
    7EB - 7E8 - 7EA are the ecu numbers
    03 -max current discharge in amps ( 3 )
    7F -max current charge in amps ( 127 )
    CB 11 - state of charge ( 51985 )??
    0 -bat temp min ( 0 )
    0 -bat temp max ( 0 )
    well thats what i got out of it!
    can anyone help me whit this!
  3. Bob64
    1,540
    92
    Virginia
    Uhh... the excel chart that your using lists ONLY PASSIVE messages, meaning they're sent no matter if you send "03cb" or not.
    Anyway this is what the message means:
    ^ this is the message id.
    03 means that there are 3 sets of (8 bits aka two hex characters) following.
    I don't know what the data (7F CB 11) means at this point.
    P.S. I don't think 03CB is a valid message to send- your only sending an message identifier, Its the equivalent of sending an envelope with nothing inside to address: 3CB.
    What your looking for is a message that starts with 03CB, your NOT sending a message with that ID, it is sent automatically 6 times a second or so.
    Do me a favor and do the following:
    Disclaimer: I am NOT 100% sure what the below message does. It is SUPPOSED to bring back a set of information that perhaps contains inverter temps. Help me at your own risk :p
    If your daring enough, do me a favor and send 07E3 02 01 C3
    and see if anything comes back...
    Repeat for 07E3 02 01 C4
  4. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    I'm not an elmscan 5 expert, but I believe following command sequense will work...
    ATZ
    ATSP6
    ATE0
    ATH1
    ATL1
    ATMA
    The last MA command stands for Monitor All messages.
    Good Luck!
    Ken@Japan
    seckwielen likes this.
  5. Flying White Dutchman
    4,374
    313
    @all - thx get back to it tomorrow i hope!
    @ken
    i have the same adapter control commands and used AT MA and got a buffer full message after a lot of messages from the canbus...
    so have to see how i can automatic delete info in the buffer of the adapter
    am going to have look in the manual again.
    maybe one of your command that you posted Will do that
    have to try tomorrow
  6. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    When I used the Agilent 6000 series MSO from work a couple of years ago, I didn't get those messages. I'm guessing your buffer is full/overrun. The Agilent has enough memory depth and speed to prevent a buffer overrun
  7. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    The CAN bus traffic is 500kbps.
    What is your serial speed? Is it still 38400bps?
    I think it's time to switch it to 500kbps.
    Ken@Japan
  8. Flying White Dutchman
    4,374
    313
    this is my response:(
    >atz
    ELM327 v1.2a
    >atsp6
    OK
    >ath1
    OK
    >atl1
    OK
    >atma
    020 00 <DATA ERROR
    030 04 00 00 00 00
    025 00 <DATA ERROR
    0B4 00 <DATA ERROR
    022 01 FD
    023 02 01 02 <DATA ERROR
    039 07 00 14 58 <DATA ERROR
    03B 00 <DATA ERROR
    03A 00 <DATA ERROR
    262 00 <DATA ERROR
    03E 15 4E A4 <DATA ERROR
    030 04 00 00 00 00
    244 10 00 00 0
    BUFFER FULL
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I keep reading the title of this thread as Prius cannabis message, which isn't at all the same thing. Every time I see it, I think "What the heck is that one about" and start to click, then realize my mistake, again, with an "Oh yea, that one..." You would think I'd learn eventually; must be the brain cells I damaged in the '60s and early '70s.
    Tom
    abdelellah likes this.
  10. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Again, what is your serial speed? Is it still 38400bps?
    Or, you have to set filters to reduce the traffic.
    Ken@Japan
  11. Flying White Dutchman
    4,374
    313
    yes i set filters now and its working better
    even if i set the speed from the elmscan to 500kbps the terminal software only works at 384kb
    is seams that only the canbus side of the elscan works with 500kbps and the rs232/usb side only works on 384kbps
    i can tell the elmscan that i want 500kbps and get A "OK" back and when i check the elmscan for its setting i see 500kbps
    but my windows pc terminal stays in 384kbps
  12. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    OK. The 500kbps is the max on elmscan, but your terminal software max is 384kbps.
    Then, have you tried the 2nd fastest 230.4kbps on elmscan?
    Ken@Japan
  13. Flying White Dutchman
    4,374
    313
    No
    funny thing is
    i can set the elmscan to 500kbps ( and get a OK back ) and stil stay connected or reconnect at 384kbps with the terminal software
    i think the elmscan usb is only a rs232 with build in usb converter!?:(
  14. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    The elmscan 5 USB is based on ELM327 chip, and it has only RS232C interface
    The chip itself does not have USB.
    Ken@Japan
  15. qbee42
    18,058
    3,074
    Northern Michigan
    This is a very common configuration for adding USB support to embedded devices. I use one from FTI on many of my designs.
    Tom
  16. Flying White Dutchman
    4,374
    313
    and is the canusb version really usb on the chip or the same.
    i got the elmscan usb because it stated it was 500kbps instead of the 384kpbs off the rs232 version
    :mad::mad:
  17. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Re: Prius canbus messages
    Look up "acceptance register"...
    _H*
  18. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Then, your terminal software does not support 500kbps...
    Are you talking about SJA1000 chip or something?
    The ELM327 does not have such "acceptance register".
    It has capability to mask/filter specific CAN-ID, though.
    Ken@Japan
  19. Flying White Dutchman
    4,374
    313
    and what do you think these codes do?
  20. Bob64
    1,540
    92
    Virginia
    They're supposed to spit back a set of data. Unfortunently, no one has ever mapped that set of data exactly. It supposedly contains inverter temps and other interesting values... I currently lack the means to send stuff to the prius, otherwise I'd try it myself.
