Prius code p3000 fan blowing hard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Killtheoldman, May 9, 2016.
  1. Killtheoldman
    Killtheoldman Junior Member
    30
    Louisiana
    My wife was driving the Prius today and triggered P3000 code, the triangle popped up and the battery blower fan runs full on. I of course googled it and see it can be due to battery overheating? How should i go about trouble shooting this?
    51,154
    what are you reading the code with?
    how many miles on her?
  3. Killtheoldman
    30
    Louisiana
    Fancy obd2 scanner from a mechanic friend,, 149000, should be mentioned i just replaced a leaky battery cell and rbalanced the battery about a month ago
    51,154
    ah, thank you. first, you should get toyotas official reader, tech stream. which will give you the details needed to make proper repairs.
    second, replacing cells and rebalancing is a very complicated and time consuming affair. did you follow detailed expert recommendations?
  5. Killtheoldman
    30
    Louisiana
    used a grid charger to rebalance and poped out the leaky cell, had some help but yes it was done right. I just ordered a mini vci scanner and techstream will give you the detail codes in a few days
  6. bisco
    51,154
    all the best!(y)
  7. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Welcome back.
    Did you test the replacement module(s) and confirm they were a good match to the other modules in the pack? If the answer is "no," then you can't say it was done right. It may be close to right, but you clearly are back to some sort of battery issue. Additionally, there is nothing preventing one of the 168 cells in the pack from imploding.
    Check back in when you've done the MiniVCI health check and logged some data on the HV battery.
    Killtheoldman likes this.
  8. Killtheoldman
    30
    Louisiana
    Will do thanks as always keith
  9. S Keith
    799
    329
    AZ
    2003 Prius
    One more thing... I don't remember in the original thread, but did you thoroughly clean your bus bars and sensing wires?
    A user recently tested and reconditioned their battery with an HA unit and even tested module capacity - replacing two bad ones. For a week, things were great... then code with a "block becomes weak" error. That block had IR in the 30s vs. the low 20s of the others. Upon inspection, his bus bars were horribly corroded on the terminal side, and he didn't notice it the first time around. Cleaned bus bars, and he's good.
    Incorrect torque on the nuts could have a similar effect. 48 in-lb.
    Techstream will likely get you pointed in the right direction.
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Given that the hybrid fan is on, it is unlikely that you have only a p3000 code.
    Likely that there is another code that you are not seeing.
    Once you have correct tools you will be able to see additional data (like vblock voltages, etc)
  11. Former Member 68813
    3,524
    983
    US
    what is the cause for that corrosion? would applying of dielectric grease help prevent that?
  12. S Keith
    799
    329
    AZ
    2003 Prius
    The copper corrodes at the positive terminal. I don't have the full explanation for it.
    He was in a coastal area. Salt laden air makes it much worse.
    Even here in AZ, we get corrosion, but it's dramatically reduced, and it's only present on the terminal side of the bus bars.
    Dielectric grease is primarily intended to seal connectors and is not recommended for use on the contacts themselves. I would be very wary of putting dielectric grease on the bus bars. 120A is a lot to push through an insulating film. I would hope proper nut torque would take care of it, but I would rather deal with the corrosion.
    The corrosion generally occurs OUTSIDE the contact area between the terminal and bus bar. It's generally not an issue until removed and re-installed w/out cleaning.
  13. Former Member 68813
    3,524
    983
    US
    actually it works great directly on the contacts. i fixed quite a few intermittent connection problems in cars, PCs and laptops by applying grease to the contacts. i don't understand how it works (contraintuitive), but it does.
  14. S Keith
    799
    329
    AZ
    2003 Prius
    It works by contact pressure scraping removing or thinning the grease to permit conductivity.
    Fixing a low current connection is one thing. Fixing a 100A connection is another. I just don't see that the benefits outweigh the risks.
    Steve
  15. Former Member 68813
    3,524
    983
    US
    Maybe there is higher contact pressure while the contacts are covered by grease?
    Either way, people who used it had great results and people who didn't use it swear against. But it shouldn't be used when sparking, due to silicon carbide fouling the contacts.
    Alternatively, one can clean the contacts, assembly them and cover the metal from outside only to seal from air.
  16. Killtheoldman
    30
    Louisiana
    No corrosion everyone, I cleaned all the contacts in the last excursion into the battery. I'll check to see if there is any change though. As for the update I finally got the software running (had to run it out of a virtual box) can someone point me to the best test to run, I ran a health check but don't see where that tests the battery
  17. S Keith
    799
    329
    AZ
    2003 Prius
    What was the output of the health check?
    When you see the list of ECU's available, double click HV Battery.
  18. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    ^^^ +1 to what S Keith said.
    Any DTC's should be on the screen after the health check completes.
    Did you get any DTCs? If so report them here.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Its corrosion from the battery gases. And the bus bars are almost 100% copper and easily corrode but the terminals are not 100% copper (too soft) so there's dissimilar metals there and a perfect storm of galvanic action and corrosive gases. Make sure you use new nuts too.
    Dielectric grease is a poor product to use there. It has no anti corrosion effects. Mainly just used to keep moisture out of electrical connections. Use an anti corrosion product like Nolox on the battery threads and a thin coating on both sides of the bar. The battery side of the bar see's the most corrosion as its exposed to the most battery gas.
    Use Nolox especially if you have cleaned off all the corrosion and exposed fresh shiny copper surface without the manufacturer patina. That surface will instantly corrode without an anti corrosion product applied.
    #19 edthefox5, May 15, 2016
  20. Killtheoldman
    30
    Louisiana
    ok got a good screen shot, so im confused, dont see p3000 like my code scanner said but I do see a host of other problems.
    To give a little background to some of these codes, I had some bodywork done, when I got it back the VST sensor was off when i inquired they played dumb. Im guessing that what the Yar sensor and etc is about. Also the airbag sensor is messed up because my kids wont stop shoving stuff under the passenger side. Outside of that the only other weird thing is the A/C has a slow leak.
    Now you have everything I know is wrong (including of couse the battery stuff we discussed preiviously) now all these codes are a bit overwhelming for me.
    Add to that none of these codes look like the p3000 code or am i missunderstanding something
      .png
      File size:
      258.9 KB
    #20 Killtheoldman, May 15, 2016
