Prius connector
Discussion in 'Gen 2 Prius Technical Discussion' started by bear15, Sep 10, 2010.
  1. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    We are looking for the connector that goes on the coolant sensor on the bottom of the canister. (See pic)
    [IMGLINK]http://mt4ima.blu.livefilestore.com/y1pbNEMA8i8NLAR7XihBlTIFHQOklpIBt0pJO5-nzN5W0_Oaemi4IgoCZYbktg18wZn13EjDGIzt5SPJ3kyVvvlcTxjCmCyTuEd/S6300171.JPG?psid=1[/IMGLINK]
    Do you happen to know where we can buy one? We are unable to find the part #, even after going to our dealership.
    Thanks for your consideration.
    -Ed
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I think this may be the part number. Not 100% sure. If you need pins for it they have a part number also. If you give me a few hours I can hunt every thing down. ( I currently need to finish a project ) If someone else has the correct numbers go ahead and post.
    90980–11061
  3. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Yes, this would be fantastic if you could provide this information.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Please verify. It is a female weather proof connector.
    Female plug.
    Part number for the plug.
    90980-11061
    Part number for the weather proof pins.
    82998-12620
    The connector is about 9$ and it looks like the pins are either expensive at about $19 each or you get multiple pins. Cant really find out as the descriptions on the net don't say. Check with your dealer.
  5. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    I purchased these from Olathe Toyota. They looked up the part # for me & ordered it. The pins are a problem. I have a cheap souce for the pins. I used Molex Part # 0194200010 They are available from Digikey at Digi-Key - WM17427-ND (Manufacturer - 19420-0010)
    and work OK, though they are not a perfect fit. I used them when I rebuilt my car 2 years ago. I also have an extra connector lying around, which I would have to check, looks like the correct one, and lots of pins. Let me know if you need them.
  6. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    How much do you want for the connector with shipping and how soon could you ship it? Thanks for ALL the help.
    Ed
  7. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    Yes, I can verify that it is the weather proof female plug connector and that this looks like the part we need. Where can I buy one?
    Cheers, Ed
  8. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    I believe I have one that I can cut from a salvage car.
    Call me M-F 8-5 mountain time.
    Eric
    Adopt A Part
    800-508-2211
  9. vertex
    670
    143
    new york
    2018 Prius Prime
    I looked at the one I have, and it is not dark gray, so it probably is the wrong one.
