Prius Custom Software Mods
Discussion in 'Prius c Accessories and Modifications' started by LnG, Dec 2, 2019.
  1. LnG
    LnG Junior Member
    73
    23
    Northern Hemisphere
    2016 Prius c
    I notice there is a section that allows you to unlock your car door when moved from park or unlock them when put into park. Has anything come out for the Prius C with more custom mods?
    What about a hybrid battery check? Dealer codes?
  2. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    I am not sure I understand what you are asking.
    Certainly there is a chapter in your Manual that lists customizable features of your car and how to customize them.
    https://www.toyota.com/t3Portal/document/om-s/OM52F96U/pdf/OM52F96U.pdf
    Page 550 begins the chapter
    Some require TechStream software or an OBDII programmer. Some OBDII Programmers run on your phone or tablet and a Bluetooth OBDII adapter.
    Torque — OBD2 Performance and Diagnostics for your Vehicle
    Carista OBD2 App | Diagnose, customize and service your car
    Most solutions that allow you to change parameters also allow you to read codes.
    I use a Scangauge II, it has hundreds of xgauges for different cars, you can train the Scangauge to read these values
    » X-Gauge Categories » Prius C
    are officail
    Scangauge and Prius c - AHA moment | PriusChat
    lists a spreadsheet they are having good results with.
    www.amazon.com/ScanGauge-Automotive-Computer-Customizable-Real-Time/dp/B000AAMY86
    BTW, in general, the more accurate your Location is, the better help you can get.
    CosmicWunderkind likes this.
    49,520
    no, nothing custom. if you want to read codes, get a prius aware scanner. same with battery testing.
    doc prius is a pretty good app, but tech stream is the offial and best
