Prius cuts off when in park
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by preachERR, Oct 20, 2017.
  1. preachERR
    preachERR New Member
    Opelika, AL
    I have a 2004 Prius with 180,000 miles on it. I have never really had any problems with it and have owned it for 5 years now. Earlier this week I was sitting in it eating lunch and an error message (car with exclamation point) appeared on the multi information display and the engine turned off. I tried to restart it but the engine would not restart. All electronics appeared to be functioning. I disconnected my battery and reconnected it, and it restarted. I was able to drive home without any problems. The next day, it did the same thing. I was able to do the same thing to get it running. So then I decided to take it to a local parts store to check for any codes but it had none. I have noticed the red "brake" light will turn off and on while sitting in park with the parking brake engaged. I really don't want to throw a bunch of money at it trying to guess at the problem. Any thoughts on what it could be?
    I have never replaced the battery in case y'all are wondering.
    49,481
    welcome!
    check the 12v health. if it's not that, you need to read the trouble codes.
  3. ChapmanF
    15,609
    I still need to figure out some way to get a nickel every time somebody posts on PriusChat and says that. :)
    When those warning lights come on, it's because there are codes. The wrinkle is, the tools at the local parts store often can't read the codes (except for the most basic, standard-for-all-OBD-II-cars ones). So you end up thinking there weren't any codes.
    As bisco suggested, getting the car scanned with a tool that can read all the codes is probably a good next step.
    -Chap
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    When I first saw that I thought you were going to quote replacing the 12V battery,
    I claim a nickel for every time somebody says to check or replace the 12V battery.
    Between you & I we will bankrupt @bisco I think. :D
    #4 Prodigyplace, Oct 20, 2017
    05PreeUs likes this.
  5. bisco
    49,481
    i have to pay the nickel?:oops:
    05PreeUs and Prodigyplace like this.
  6. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    Me too. :D
  7. ChapmanF
    15,609
    Ok with me if you want those nickels. I don't think I could handle the weight of them all.
    -Chap
    Prodigyplace likes this.
  8. Prodigyplace
    11,696
    11,318
    Central Virginia
    Between trouble codes and 12 V battery I think @bisco post count would be cut by a third if they were eliminated. Remove “All the best” and another large chunk disappears. Is @bisco a robot? :eek: :D
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Most likely you have a worn out very old original hybrid battery.
    It’s the second most reported thing here. It exhibits itself as fast charging on the mfd and fast discharging and tanked mileage. Throws master caution light on dash and the car turtle icon on upper left of mfd.
    #1. Bad 12 volt battery. That seems quite a mystery to people.
    #2. Bad hybrid battery. It’s time. Thousands of posts about about it.
    Unfortunately even though it’s a huge post count and a very specific
    Issue there is no exact forum for it. Info is spread around all over the g2 forums so you have a lot of reading to do, use the search tab at the top and search
    Hybrid battery
  10. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Based on these three statements, I suggest looking at the 12v battery first. (Where do I send my nickel?) :p You can have it load tested at an auto parts store for free.
    If OK, you'll need to get the codes read by a system that can see Toyota specific hybrid codes. Dealers diagnostic fees tend to be high so check with a hybrid repair specialist or research methods to read them yourself (techstream, OBD readers, smartphone apps, etc).
    Raytheeagle likes this.
  11. preachERR
    Opelika, AL
    Ok I replaced the 12v battery. I cranked her up and within 5 minutes, same beep and master warning light appeared but the engine is still cranked and I still have my "ready". I haven't had time to take it to a shop to hook it up to a more in depth monitor. Any other ideas before I decide its fate? Is there a test I can do myself to check the health of the high voltage battery?
    If it comes down to the high voltage battery needing replacement, I'm going to sell it.
  12. edthefox5
    10,096
    4,806
    Clearwater, Florida
    get ready to sell it.
