Prius died while driving... now won't start. Says check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drewbabich, Mar 17, 2016.
  1. drewbabich
    drewbabich Junior Member
    68
    My 2010 Prius died while driving... i had to pull over, now won't start. Says check hybrid system
    What the heck should I do.
    These cars don't have alternators and I still have my electrical acessories working so I don't think the 12v battery is dead
    anyone ever have a prius die while driving?
    DLC82SV likes this.
  2. JC91006
    16,482
    8,400
    There's a recall on the inverter, most likely the failure in your car
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yup sounds like the inverter overheated.
    DLC82SV likes this.
  4. matt b.
    matt b. Member
    251
    60
    L.A.
    Check your rear cargo battery and the others have each battery checked
  5. matt b.
    matt b. Member
    251
    60
    L.A.
    Do you have any other symptoms? Does your HUD display show any life at all?
  6. matt b.
    matt b. Member
    251
    60
    L.A.
    Take the car to Toyota have the car towed to Toyota have Toyota do a diagnostic on the car
  7. matt b.
    matt b. Member
    251
    60
    L.A.
    Because what you think is not going to solve the problem
  8. bisco
    49,504
    did the serpentine belt break? is there any gurgling in the coolant tower?
  9. prev93
    prev93 Member
    63
    Califon, NJ
    No belts in the 2010
  10. bisco
    49,504
    timing chain?
  11. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    If I had to guess, the Inverter probably failed.
    DLC82SV likes this.
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Sounds like the inverter to me too. Op has an early 2010 (despite their profile saying otherwise) and the early 2010's did seem to have an inverter issue - I found out the hard way.
    Wonder if that software update 4 years ago actually helped take the strain off the inverter? I also wonder if the OP's car has had that update?
    Mine was replaced outside of warranty as I had a full Toyota service history. Perhaps that's an option the OP could investigate? (assuming they have a full Toyota history).
    DLC82SV likes this.
  13. DLC82SV
    DLC82SV Member
    241
    119
  14. DLC82SV
    DLC82SV Member
    241
    119
    Now they issue a recall...
  15. KeleStanley
    KeleStanley New Member
    Springfield, Ohio
    I get this all the time. It will cut power to the combustion engine and will go 42mph on the electric system until the battery is depleted. It is very dangerous because it always happens on the highway. Toyota knows about this and it almost seems like someone will have to die before they do something about it. I have done the cleaning on the EGR and intake which I believe were causing misfires that has led to a blown head gasket. Toyota will tell you it's out of warranty knowing darn well the reason it is doing what it is doing is a direct result of their hardware and software. Get out your wallet and guessing game.
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Isn't there a recall now? So it would be a free repair? I don't have a Gen-3 so I don't follow the recalls as closely, but I thought I heard mutterings.
