Prius EGR gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TerryZ91, Apr 26, 2021.
  1. TerryZ91
    TerryZ91 Junior Member
    Chicago, IL
    I was cleaning the EGR off my Prius and during the disassembly, I seem to have lost one of the gasket. Unfortunately, it's the gasket that the dealer doesn't sell. It's the gasket that goes between the egr valve and the pipe housing. Here is a picture for reference. Does any one know the part # or other gasket that it could be replaced with?
    Thanks!
  2. Mendel Leisk
    41,901
    It’s a 3rd gen, and just for the record, what year? There was a rev to the valve part no IIRC.
    I’m thinking the “valve” part number comprises both sides of that bolted connection, and the bolts. The question that poses for me: IS there a gasket?
    I did this 3 years ago, but think I can remember...
    Watch the @NutzAboutBolts video (link in pinned thread at top of maintenance forum) on Exhaust Gas Recirculation cleaning, to verify there’s a gasket. If there is, do you need to buy the whole valve? :eek:
    part no’s, 2010 model year :
    Exhaust gas recirculation system for Toyota Prius 3 generation 01.2009 - 11.2011 - Toyota Car & Auto Spare Parts - Genuine Online Car Parts Catalogue - Amayama
  3. TerryZ91
    Chicago, IL
    There is a gasket. Nutzaboutbolts video at 18:50 mark. He takes out a small gasket. That's what the dealer told me, that I may have to buy the whole EGR valve assembly for that gasket. It seem waste of money since all I need is the gasket.
    My prius is 2014
  4. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Unfortunately it's all one piece. I'm seeing used on ebay for $75. You can hit up @ozmatt to see if he can help you offset some of the cost. He was looking for a spare magnet inside the stator.
  5. Mendel Leisk
    41,901
    One thing bugging me: the gasket pretty much has to come off after the valve/cooler is off the car; is that your case? So it wouldn’t be dropped in the engine bay? Search some more?
  6. TerryZ91
    Chicago, IL
    I looked everywhere, even in the trash. I took the cooler apart to clean it a week ago. Due to work, didn't get to clean it until yesterday and when I was ready to put everything back together, I noticed that the gasket is missing.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    SFO and Mendel Leisk like this.
  8. TerryZ91
    Chicago, IL
    That looks very similar to this part # 25634-37030. That is the one that goes on after the assembly between the pipe and the valve. See picture for reference. Is that the one you’re referring to?
    https://www.ebay.com/itm/Genuine-EGR-Valve-Gasket-2563437030-for-Lexus-Toyota-/114571741158
  9. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    Take the gasket you do have (25634-37030) and see if the holes line up at the end that's missing a gasket. If they do, I suppose you could order another one of those gaskets and snip the tabs off to make it fit?
  10. AzusaPrius
    2,232
    930
  11. Mendel Leisk
    41,901
    Toyota is calling the valve, comprising 2 aluminum pieces, 2 bolts and a gasket, a “part”. Which is frustrating.
    in a pinch you could even fab a gasket?
    Montgomery likes this.
  12. TerryZ91
    Chicago, IL
    Unfortunately, I tried that and the gasket is too small. The diameter of the pipe opening is perfect but the holes for the bolt/nut don’t line up, they need to be spread out little more.
  13. TerryZ91
    Chicago, IL
    I agree, it’s frustrating. I have no idea how to fabricate the gasket. I just ordered a used egr valve. Will reuse the gasket from that to put mine back together. Before that I am thinking of going to local auto parts store with the old gasket and see if they can help me find one aftermarket one that may fit. I’ll post a solution here if there i find one in case someone has similar issues in the future.
  14. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    To repeat Mendel, you can get gasket material and cut your own. Its old school and done all the time. Faster and does the job!
  15. ChapmanF
    18,546
    These gaskets are a thin springy metal. Maybe you could follow the same technique, but how you cut the material might be a little different.
  16. Mendel Leisk
    41,901
    Yeah that makes it very difficult to DIY, the OEM. A very thin and slightly compressible material “might” serve in its stead.
  17. ChapmanF
    18,546
    and high temperature
  18. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Here in Australia we would just cut one out of a disposable oven tray, and drive!.. lol ? :) ...
    the rotor i hack fixed is still working, still seeking a good spare for the shelf!
    wheezyglider and sLick415 like this.
