Prius electric motor surging
Discussion in 'Gen 2 Prius Main Forum' started by pfbloom, Jan 11, 2012.
  1. pfbloom
    pfbloom Junior Member
    Vermont
    First post: so I'm test driving a 2007 Prius II with thought of purchasing and notice a strange phenomenon: driving at steady speed of about 50 mph on a flat rural highway, the electric motor pulses on and then off about every 15 to 20 seconds. This happens on the flats or slight incline, and causes a noticeable and continual surge and retard in the car's driving.
    Temp today around 21 degrees F here in Vermont. The car coasts great and accelerates under strong load okay. Seems to drive much more smoothly when I put cruise on, but still surges intermittently. Driving 60 to 65 on the smooth Interstate seems to show little of this phenomenon.
    Is this to be expected?
    Note that I have owned a Honda Civic Hybrid for six years and believe I've developed a very light and steady foot, so don't believe that is the issue. My guesses so far:
    1. I'm just not used to the Prius drive-by-wire throttle sensitivity
    2. There is an innate issue here at 45 to 50 mph where the Prius software or drivetrain has a hard time making up its mind/
    3. There is something the matter with this particular car (maybe a faulty accelerator pedal assembly or the fuel pedal relay?)
    4. There are car settings that can be adjusted by a skilled mechanic
    Checked the threads here and see some mention of temp-related surging, and of speed around 42 mph surging. Also that Consumer Reports noted a surging issue with Prius (?)
    Is this just the way Gen II Prius drive? If so, it seems that my Honda Hybrid software handles the gas/electric switching much better than Toyota, especially at the 45 mph speed threshold.... anyone else experience with this?
  2. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    There may be something wrong with the car. I have 105K miles on my 05 and have never noticed any type of surging.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I have over 155,000 on the clock and never experienced a surging issue. I'm curious what the problem is.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Doesn't sound normal to me. I've had my 06 for a few weeks shy of 6 years now.
    Try test driving another 2nd gen Prius, for comparison. Also, you didn't drive in B mode, did you? (Side note: Cruise control can't be engaged while in B.)
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    I have an 07 also and mine is smooth as can be.
    You can see whats being used primarily if you look at the mfd consumption screen arrows.
    But I think you may have a slight miss in the engine and your feeling that. Usually a very dirty throttle body can cause that. It can't be bad whatever it is or it would throw a cel. The car is real good about complaining when its unhappy.
    Whats the mileage?
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    There are no settings to adjust.
    This is a case where posting a youtube vid of the MFD + speedometer would be very helpful. Another issue: an electric motor is always engaged. It is only the gas engine that turns on/off.
    In 4 cylinder cars with A/C compressor clutches, it is usually possible to discern the clutch engaging or disengaging. To me, that is how it feels when the Gen II gas engine turns on or turns off when the car is moving.
  7. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    For me, it's obvious when the ICE turns on. The shutdown is obvious when stopped and usually is noticeable at very low speeds, esp. if it's a rough shutdown.
    However, there are cases below 41 mph but above low speeds that it's impossible to tell by feel and sound that the ICE has shutdown. Only way to tell on those cases is by seeing ICE RPM drop to 0 on ScanGauge II.
  8. pfbloom
    Vermont
    Hmmmm, as further clarification -- glancing at the MFD display while driving I see that the electric motor is switching off and on every 10 to 15 seconds (and this small electric boost is probably causing the surge as it switches on and off). BTW, car has 56K miles.
    So the conditions are these:
    • level road or slight incline
    • steady speed of between 45-50 mph
    • light steady pressure on accelerator to maintain speed
    • MFD shows yellow arrows to drive wheels indicating continual short bursts of electric motor boost
    Thanks all for the feedback. Do you think the ICE occasionally missing is a possible explanation? Still hoping to get to the bottom of this.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I can't necessarily speak to the changes when using light steady pressure but the arrows going back and forth are totally normal if using cruise control.
    I do use the MFD when trying to deadband while doing pulse and glide (http://www.cleanmpg.com/forums/showthread.php?t=1224). Once the ICE is warmed up, it should be possible to deadband w/o too much difficulty. You should be <41 mph.
    How about you just ignore the display, switch it to something else or turn it off? Maybe it's all in your head or you are getting thrown off by the display.
  10. uart
    uart Senior Member
    4,215
    1,201
    Australia
    It's completely normal for the MFD to display electric motor activity like that, but it's not normal for it to create any type of surging.
    So the only two possibilities are:
    1. You are imagining it. Looking at the display and seeing the arrows doing their dance is putting the idea into your head about the surging.
    2. The Prius is faulty.
    Try driving another Prius. If you don't notice the surge then option 2 above was the case, otherwise I'm afraid we have to go with option 1.
  11. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Yep... for option 1, that's why I suggest he turn off the MFD or switch it to something else.
  12. pfbloom
    Vermont
    Appreciate the speculation, and I would not rule out pilot error myself... However I can definitely feel a repeating surge/retard at this 45/50 mph speed threshold, even when the MFD Display is off. Tried looking away and only glancing at the MFD when I felt the slight surge/retard, and the electric boost seems to coincide with the bis feeling of surge (even accounting for the 3 second refresh rate). And as mentioned I have driven a (Honda) hybrid for many years and am somewhat familiar with the subtle kick-in of electric boost... perhaps I just need to get used to it happening with less subtlety on the Prius?
    So I am a little more inclined to speculate it is answer #2, and am wondering whether there may be a throttle switching problem (which was discussed in one earlier thread here) ?? I am noting that the surging is most apparent under very gentle acceleration maintaining speed in the 45/50 mph range. It does appear that the issue is less pronounced when cruise in ON, which I suppose would support both theories.
    Wonder if the throttle operation is easily testable? Do you think that a subtle surge would necessarily register on the speedo? I know on my Honda the electric kick-in is very subtle, and barely noticeable unless you are an experienced driver.
  13. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi pfbloom. There is one specific anomaly in the Gen2 prius that can cause a very minor surge/retard type of thing, but it only happens if you're coasting or gliding at 41 - 42 MPH (specifically as your speed crosses above or below this 41 - 42 MPH threshold).
    This happens because it wont do a true glide above 42 MPH, so it has to start the engine. The upshot is that if you're trying to glide or coast very close to 41 MPH then you sometimes notice a very slight feeling of pulsation as the engine is forced to start and stop each time the speed varies a bit above or below this threshold.
    Given the speed and the energy monitor display you report however, this cant really explain your pulsations.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The Gen II Prius does produce a mild surging sensation when traveling straight and level down the highway. It is very slight; many people might not notice it. When I first got my 2006 I noticed it, as well as wandering at highway speeds. I don't notice anymore, as I have become accustomed to the idiosyncrasies of the Prius.
    A pronounced surging is not normal. I recommend driving another Gen II and comparing.
    Tom
  15. pfbloom
    Vermont
    Interesting response, Tom, and more along the lines I have been experiencing; the surging is very subtle and might not be noticed by many, but I can sense it when I pay attention..
    Wonder if others concur with Tom's experience, and/or whether the newer Gen III Prius has more sophisticated software that corrects for the "mild surging sensation" he mentions in Gen II versions....? This is what I have been experiencing.
    Perhaps it is something one gets quickly used to, but odd to me as my Honda Hybrid exhibits smoother driving manners than this.
    Paul B.
  16. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Ok I guess I misunderstood your original post. I thought you were referring to a much more pronounced type of surging.
    I suppose the control system that manages the distribution of power between the electric motors and engine is not exactly perfect. Next time I'm on a really smooth flat road I'll have to see if I can notice anything.
  17. defrankond
    defrankond Member
    217
    23
    North Dakota
    I get the same feeling in my 2010 from time to time. Happens at highway speeds or city speeds. Kind of feels like the transition between hybrid and elect functions only it only happens when the ice is running.
  18. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The only time I've noticed anything like this is with the cruise control activated. I feel the cruise control is pretty aggressive at maintaining the set speed, and will sometimes initiate more power demand than I would in order to do so. I haven't felt anything like that otherwise, though, aside from the very slight "bump" sensation when the gasoline engine starts and stops at speeds below 42 mph (or moving in and out of that threshold, as uart mentioned). I may have also felt a slight bump when one of the motor/generators reverses direction, but I'm not sure about that--just a hunch.
    The Toyota and Honda hybrid systems are very different (let me give this a shot--others feel free to make corrections). Honda uses a series-hybrid configuration, which is more like a gasoline engine power train with supplemental electric drive assist and regenerative braking. Toyota uses a parallel-hybrid configuration, with the electric drive/regen and gasoline engine each holding up their own ends (of the power-split device), more like an electric car with gasoline engine assist. Each side has much more independence than in a series-hybrid system, and the parallel system is much more dependent on the electric drive than the series system. In the parallel-hybrid system, the only thing that "kicks in" and out is the gasoline engine (at speeds below 42 mph). At speeds above 42 mph, the gasoline engine must spin but there may or may not be fuel delivered to it. In the series-system, I believe the gasoline engine will not stop unless the car is stopped.
    While traveling with fixed position of the go-pedal, the gasoline engine RPM and load and electric drive torque should stay pretty constant. This is not at all the case when trying to travel at fixed speed--then power demand and energy flow tend to shift pretty wildly.
    You could try the old Jeepers' trick to maintain throttle position by digging the side of your go-pedal foot into the transmission tunnel. The travel of the go-pedal on these cars seems very light and it can be difficult to judge pedal pressure and position.
    I agree that some insight could be gained by driving another Gen II.
    #18 tanglefoot, Mar 6, 2015
