Prius electrical problem
Discussion in 'Gen 3 Prius Audio and Electronics' started by Arsal mehmood, Jan 3, 2023.
  1. Arsal mehmood
    Arsal mehmood New Member
    Japan
    My prius headlight, windows, eco mode power mode and ev mode not working and also can't open trunk and can't lock and unlock the the car with smart key
  2. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    Might be easy like time to replace the little 12V battery in the right rear corner of the car. Have it checked first, which usually doesn't cost anything. The battery is usually good for 4-6 years, unless drawn down by a door open or using accessory mode.
    Montgomery likes this.
  3. nicoj36
    nicoj36 Active Member
    495
    158
    Check fuses and have 12v battery tested
    49,488
    rodents?
