Prius engine vibration for few seconds after engine oil and transmission fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hc167, Sep 24, 2016.
  1. hc167
    hc167 Member
    132
    US
    I just changed my engine oil and transmission fluid today since I bough my Prius 3 few months ago. After both the oil and transmission fluid were changed. I turn on the car and tried to have a test drive. The car vibrated for 3-5 seconds when the ICE started. I was worry and then shut off the car. Then I started again, vibration came back when the ICE started again for 2 seconds, then vibration disappeared. since then I didn't have this issue. I have never have this issue since I bought the car. I am not sure this is cause by oil change or transmission fluid change.
    The vibration sound like those in early 2010 where people start the Prius in the morning and the engine start knocking for few seconds. And I think TSB said it was due to intake manifold defective design causing misfire. I don't think my car have this issue since it is 2012 and I believe Toyota fix this issue for 2012. Is it possible that after changing oil, oil pump completely run out of oil? I have no idea why and this is the first time I have this experience after oil change. In fact, I have no idea this is because of oil change or transmission fluid change.
    Please let me know if anyone know what is happening. Thanks
    51,695
    it wasn't fixed. did you previously start the car, then shut it down while it was warming up?
  3. hc167
    hc167 Member
    132
    US
    What wasn't fixed? you mean the intake manifold issue? I change both oil and transmission fluid today. And Today temperature is about 65 in the afternoon. The car was not warm up. It was obviously cold since I was changing the fluid. I started the car when I finish changing both fluids. Are you saying that 2012 Prius still have issue for misfire?
    51,695
    yes, improved, but still there.
    what i'm asking is, before you did the fluid changes, did you start the car, move it around your yard, and shut it down while it was warming up?
  5. hc167
    hc167 Member
    132
    US
    To your answer, yes,
    It was not driven for the entire day except it was moved in front of my house from one parking spot to another (less than 40 feet), which should not heat up the car a lot. Then I pretty much spend two and a half hours jacking up the car, putting the jack stands, removing the panel underneath, and so on..
    Is this the reasoning?
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    How much transmission oil did you add? What about engine oil? How many miles on your Prius? Did you switch it into EV mode when movin the car, or did the ice kick in?
  7. hc167
    hc167 Member
    132
    US
    I add little over 4 quarts for transmission fluid (maybe 4 quarts 2 oz). For engine, I add four quarts. The car has about 41K. The car was moved twice, once at about 12:00pm today with ICE on. The seconds time was right before I changed the fluids at about 3:40pm (I forgot rather I was using EV mode or not). Then I started spending two and a half hours working on it. At around 6:15, I started the car.
    Raytheeagle likes this.
  8. Mendel Leisk
    41,130
    The one time I got shake at startup, quite recently, was when I started up with stone-cold engine, then shut it down within a few seconds. Next day when I started the car, it was shaking. Shutdown and restart, the problem was gone. Guess what we're alluding to: hopefully it's just coincidental to the fluid changes.
  9. hc167
    hc167 Member
    132
    US
    Oil was Mobil One EP 0w-20, filter is Bosch long life filter. trans fluid is Toyota WS-ATF
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Did the ice complete a cycle or did you stop it mid cycle?
  11. hc167
    hc167 Member
    132
    US
    Since I changed both fluids at the same time, I have no idea what is causing it if it happens to have to do with fluid.
  12. bisco
    51,695
    that's why you had the vibration, nothing to worry about. when you start it from cold, try to wait until it shuts down on its own, before powering down. nothing to do with the services you did.
  13. hc167
    hc167 Member
    132
    US
    What do you mean? what cycle are you referring to? The engine four cycles? or the cycle that the engine kick on and shut off?
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    The cycle where the engine starts and then off. If you shut it off mid cycle, there is a risk of having the knock like @Mendel Leisk describes.
    I take it no codes were displayed on the dash?
  15. bisco
    51,695
    see post #12.;)
  16. hc167
    hc167 Member
    132
    US
    no code was displayed
  17. hc167
    hc167 Member
    132
    US
    Toyota did not fix it since 2010? Is there a TSB for this? So this was the same knocking problem of 2010 Prius on the intake manifold?
  18. bisco
    51,695
    correct. i think there was a tsb, but the new manifolds still have the problem. maybe not as often.
  19. hc167
    hc167 Member
    132
    US
    OK, thanks. This is no good, Toyota hasn't done enough testing for their products before releasing their product. This Prius simply use Corolla engine. Is there similar issue for Corolla, Or corolla just uses different manifold?
  20. bisco
    51,695
    i'm not sure about the difference that causes the problem, but the prius engine is tuned completely different than corolla. valve timing is a big thing, and unburned hydrocarbons remain in the manifold when the engine is shut down cold.
