Prius floormat question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mikedamirault, Jan 27, 2011.
  1. mikedamirault
    mikedamirault Junior Member
    Dublin, OH
    I have tried looking everywhere but can't find the answer
    I am cleaning my car out and can't seem to remove the driver side floor mat (can't remove it from the two hooks), is there a special way they are supposed to be removed? I have checked the manual and online and there seems to be no information on it
    It's the first of the third gen Prius if that helps any, thanks
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It's tricky. Place one hand underneath the mat near the hook and lift up while pushing the tip of the hook in using your other hand, one hook at a time.
    2 people like this.
  3. mikedamirault
    Dublin, OH
    Thanks
    I did end up getting it off using a pair of needle nose pliers, I'll have to try out your suggestion and see if it's easier
  4. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    I just pop the hooks out from the floor then pop them back in. :)
  5. Mendel Leisk
    40,574
    The mat can be lifted off the hooks, but: they're a lot more tenacious than our previous Honda mats. Maybe purposely, due to the floor mat jambing accelerator issues?
    You need to get a hand under the mat, flex it up onto the tip of the hook, push down on the hook, up and back on the mat, dump half the accumulated grit onto the carpet in the process.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    As previously stated, I lift from underneath behind the eye then push forward. They get easier and loosen up with more removals.
  7. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Just do a once-over with a vacuum before you take it out.
  8. Ontarget
    Ontarget Junior Member
    30
    Hudson River Valley, NY
    That kind of defeats the purpose of a quick shake outside of the car to help keep the carpeting clean. I was not impressed with the oem carpeted mats for protection and opted for the Husky floor liners. (which may stay in permanently)
