prius front brake pads
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by johns, Aug 8, 2009.
  1. johns
    johns New Member
    north carolina
    replaced front pads 07 prius(not by me) with pads from advance auto parts store said to have been ceramic car now has brake squeal what is best to use for relacement
  2. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    That's easy - replace with the OEM parts. Brake pads are part of a tuned system, believe it or not. We take great efforts to minimize noise during braking. Each component is kind of like a tuning fork - hit it correctly and it makes noise. We design the parts so they each ring a different frequencies. The brake pads you now have clearly excite a different frequency than what was designed by Toyota. The OEM parts are usually your only choice if you want to avoid noise and/or pulsation.
    An automotive brake engineer.
    2 people like this.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Good advice.
    Tom
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    First time DIY front brake pad replacement on my Subaru about 10 minutes ago. I know -- kind of embarrassing, but better late than never.
    I'm pretty sure I kept the inner pads correctly oriented between right and left with the clip on the top, but I am curious how much it matters. Anybody know ?
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Have to agree with mdacmeis, everytime I have used non-OEM brake pads I have had some different reaction. squeeling, noise, slippage etc. It makes sense that the pads are designed around the rest of the assy and for compatibility. If I ever have to change pads, which is unlikely, on the Prius I'll go OEM.
  6. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    My question is why would you replace the pads in the first place? Replacing Prius brake pads is something generally reserved for cars with over 100,000 miles (or even several times that!).
  7. patsparks
    10,664
    567
    Adelaide South Australia
    My front pads are still very serviceable but I have a set of OEM pads in the garage for the day I need them.
    I used to use after market parts but now I'm a convert to OEM Toyota branded parts only.
  8. jeg
    jeg Junior Member
    Monarch Beach, CA
    Years ago, I bought the "cheapest non-metallic" brake pads available at Auto Zone. Auto Zone's pads are "guaranteed for life". Once you buy them, return them prior to the pad going to metal and they will give you a brand new set for FREE! I am approaching 150k miles on my 2005 and I have not paid for brake pads in the last 4 years. Furthermore, since the pads are non-metallic, they do not cut through your rotors and they don't squeal. That's a good thing! :playball:
  9. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    FYI, a PriusChatter has reported to me that he replaced his 07 Prius front pads a couple of years ago with Hawk Performance Ceramic pads, and that he's never experienced any additional noise/squealing whatsoever.
  10. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    I am the PCer who replaced the OEM brake pads with Hawk ceramic pads the moment the car rolled off the transporter (4 ish miles were on the odometer). I have had zero noise, significantly less dusting and compared to other Prius' that have been serviced by the dealer that sold me my Prius, less wear of pads or rotors. My stopping distance from 60 mph to 0 is around 115 feet, but part of that is due to the wider (205 mm) tires that are on my car.
    If you are looking at new pads, Hawk ceramics (this is the 4th car that I have put Hawk ceramics on) have worked quite well for me.
    2 people like this.
  11. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Whad'ja put in the rears, out of curiosity, or was it only
    Hawks in the front?
    _H*
  12. apriusfan
    6,050
    205
    S.F. Bay Area
    Hawks in the front.
