Prius G3 Misfires/Head Gasket issues same as in Lexus Ct200h?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SacLexToy, Nov 11, 2018.
  1. SacLexToy
    SacLexToy Junior Member
    Sacramento, CA area
    Hi All, first post here. Reading a lot about the engine misfires on startup (with P030x codes) and the issues with EGR, intake, and head gaskets on the G3 Prius. In my case, I just started having the same symptoms on my 2011 Lexus CT200h. I believe it is the same engine (2ZR-FXE) and drive train. A search of Lexus forums has a little info on it but not nearly the same number as here. Any input on next steps or final resolution to this issue would be appreciated.
    To answer some common questions:
    Car: 2011 Lexus CT200h
    Mileage: 159k
    Symptoms: Shake/shudder on startup, seems worse when car is restarted when still warm (30-45 minutes after shutting off). CEL on: Codes thrown: P0300, P0301, P0302, P0303, P0304. Started about a week ago, not all codes get thrown every time car is started.
    Oil Usage: None, Have never added oil between 10k changes with full synthetic. Oil appears completely normal (no milky appearance) and no crud on underside of filler cap.
    Coolant Usage: Slight drop noticed after problem started. Topped off and no noticeable drop yet, though I have minimized starting/driving car. My OBD2 scanner shows coolant temp of 180-190 after 30 minute drive; I don't believe it has ever overheated. Coolant was changed at 120k with Toyota Long Life; old coolant looked exactly the same as new coolant.
    Smoke from tailpipe: Very slight, only immediately after starting for 5-10 seconds. You would need to be standing there looking for it to even notice.
    EGR: Lexus had a service campaign on this issue way back in 2012 or so and I did take car in and have that done, as I recall they replaced "EGR control unit." Haven't touched it since (my bad evidently).
    Done so far: After very first CEL/Code of P0302, I swapped coil and plugs between Cyl 2 & 3 to see if code followed coil. It didn't. Next code read showed P0302, P0300, P0304. Took to independent shop who diagnosed bad plugs (I changed out originals at 110k with OEM Densos), They were confident new plugs would resolve: it didn't.
    Questions: Am I looking at first signs of HG failure? Could it be EGR cooler leak instead of head gasket? Is the complete EGR cleaning doable by shade tree mechanic? (I have done all the oil/filter/coolant/plugs/brakes on this car since new). If it is HG, is replacing it better than swapping engines, giving my no oil usage on this engine? This has been too good a car and in in such good shape otherwise, I feel it is worth fixing but I don't want to assume the worst and I don't want to be at the mercy of diagnosis of shops not very familiar with this specific problem, they just guess and start replacing parts that do not fix. Thanks for any suggestions!
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    While this sounds like the first signs of a head gasket failure, some questions:
    • What mechanic did you take it to?
    • Sounds like you are the diy type. Would you try to diy this?
    • Have you pulled the egr pipe to see how bad the plugging is?
    Good luck and keep us posted (y).
    Bay Stater, SacLexToy, m.wynn and 2 others like this.
  3. SacLexToy
    Sacramento, CA area
    Thanks Ray. Thanks for quick response! I took it to Ozmotive in Sacramento. They specialize in Hondas and Acura but they work on all Japanese cars and have done a good job for me in the past. But I just don't think they're familiar with this particular problem, so I hesitate to return there. I have not pulled the EGR pipe and it is something I might attempt to do myself as well as the full EGR cleaning process. I'd like to make sure that is in good shape before I proceed with any other major repairs. Does that make sense?
  4. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Absolutely ;).
    I’ve done the egr circuit 6 times on the Gen3, so I’ve seen how bad it can be:cool:.
    Let me know if I can help(y).
    Bay Stater, SacLexToy and m.wynn like this.
  5. SacLexToy
    Sacramento, CA area
    Thanks. At this point I'll take all the help I can get! With 6 EGR jobs under your belt, you sound like an expert to me!
    I see you're in Fairfield. Not that far from me (I'm about an hour east of Sac). If you have time and want to supervise the job so I don't screw it up, I'd be happy to bring the beer, or your drink of choice! Or we could do it here. -Dan
  6. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Get a bore scope and look into cylinder 2 and 3 . I can almost guarantee you will see a few drops off coolant . Sounds like typical Toyota head gasket failure
    Bay Stater and SacLexToy like this.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    It just so happens that next Sunday is meet up Sunday in Fairfield :):
    Possible Monthly install meets. Bay Area-Fremont
    If available and want to do the job, sign up on the list there;).
    If doing the egr circuit, I’d come early as we lose light a lot sooner these days(y).
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Luckily I have one of those:).
    Might get some use next weekend(y).
  9. Mendel Leisk
    41,471
    @SacLexToy, the above is relatively easy and quick. It's not the full EGR system, just the connecting pipe between EGR valve and intake manifold. Removing it and checking it's condition (carbon build-up) will give you some idea of the rest of the EGR system. Watch @NutzAboutBolts video on EGR pipe cleaning, in a thread pinned at the top of this forum.
    With your miles it's pretty much guaranteed to be getting along, getting clogged. Properly flowing EGR is apparently essential to keeping engine temps down, and elevated temps are tough on head gasket. It's a viscous circle.
  10. SacLexToy
    Sacramento, CA area
    Thanks @Raytheeagle, @xerox6135, and @Mendel Leisk. I'll try to look at the EGR pipe myself this week to see what it looks like.
    I'd love to come to the meetup on the 18th if y'all don't mind a Lexus CT200h invading your Prius group! I've spent the morning watching @NutsAboutBolts videos (great work! thanks) on EGR cleaning and intake manifold cleaning. Never done any of this stuff before and some experienced eyes and guidance would be very helpful and appreciated!
    The car has ran so well for so long (has NEVER been to a shop for any repair of any kind, other than Lexus recall/service bulletins!) that I haven't been proactive enough to be aware that this EGR issue might be a silent death slowly creeping up on me. I've done all scheduled maintenance myself and thought the car would last many more trouble-free years. And then boom, one day the shaking on startup and MIL/CLE light with P030x (misfiring) codes.
  11. SacLexToy
    Sacramento, CA area
    Removed the EGR pipe today to take a look. It was definitely gunked up but air still flowed freely through it. Some before/after cleaning pics are attached (if I can figure out how to attach or have rights). Does this look normal for 159k? EGR_Pipe_Intake Side_combined.jpg EGR_Intake_port.jpg EGR_Pipe_EGR Side_combined.jpg EGR_pipe_EGR_port.jpg EGR_pipe_what_came_out.jpg
  12. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The pipe on mine that grenaded was about that dirty. Your buildup looks to be a drier, more powder soot. Mine was obviously wet, oily soot.
  13. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    It's possible. Your EGR valve and cooler are at least partially clogged. I highly recommend taking up @Raytheeagle offer to get it cleaned.(y)
  14. Mendel Leisk
    41,471
    It's hard to tell, I think the pipe always looks worst at the ends, but from the looks of there's there's definitely going to be significant restriction in the EGR cooler, with the pipe looking like that. Just going by the miles too: it's almost a slam dunk it needs doing, EGR and intake manifold.
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Good thing you are penciled in for the egr circuit cleanse ;).
    If you aren’t losing coolant yet, we’ll have caught this in time:).
    I got another PM request for circuit cleansing, so you’re it if you want to attend(y).
    Bay Stater, m.wynn and SacLexToy like this.
  16. SacLexToy
    Sacramento, CA area
    I will come on Sunday for the EGR circuit cleaning. Thanks again for the invite. Where in Fairfield is the meet? Time? What should I bring in the way of tools, cleaner, etc.? Don't know that I have all the specialty tools for removing studs.
    And just throwing it out there, what is the concensus on driving the car there if this is a head gasket issue I am facing? Do I risk damaging the engine further? It's about a 90 minute drive to Fairfield. I am not sure if I am losing coolant since haven't driven it much at all since this started. But after first codes, the coolant level was lower than it has ever been, so suspect I am.
    Also, I did notice that, compared to @NutzAboutBoltz videos, that my 2011 Lexus CT engine bay is not identical to his Prius. All the components seem the same but the layout is slightly different. For example, I do not have to remove wiper motors and cowling to change my spark plugs, the MAF sensor plugs in at different spot on air cleaner housing, etc. Not sure about the rest of EGR system.
    #16 SacLexToy, Nov 13, 2018
    Bay Stater likes this.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Those that sign up for the meetup, I send a PM to with more details for the event :).
    As for other facets of your post, I’m on the northern end of Fairfield, and the risk of head gasket failure is the same as you’ll probably drive it regardless ;).
    I have all the tools needed for the job, but come early so we can work on the subtle differences and get you out the door before sunset (y).
    Bay Stater and m.wynn like this.
  18. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Consumable parts & cleaners such gaskets, fluids, bulbs, grease & etc. you supply those. Heard someone is bring beer.
    Tools such as jacks, torque wrenches, wheel chocks & other misc. tools will be there. If there's a specialize tool needed, feel free to check in with us if the tool will be there before the meet up.
  19. SacLexToy
    Sacramento, CA area
    I will bring beer!
    You guys have a favorite flavor?
    Does the EGR cleanse require any new gaskets?
    Grit, Raytheeagle and Bay Stater like this.
  20. Mendel Leisk
    41,471
    I don't think so. The only flexible gasket is between EGR pipe and instake manifold, an orange/red O-ring, and it's pretty durable. Everything else is uncoated metal gaskets; they're fine as long as they don't get bent.
    One thing: the rearmost gasket, between cooler and exhaust manifold, has no retaining clips, which is really a design oversight. Watch for it: it's really easy to drop. It's also tricky to reinstall: clips would really help, align it.
    See if you can drain a couple of liters from the radiator at the outset, into a clean container, that'll avoid all coolant spillage, as long as you're careful lifting the cooler out (there will be a few tablespoons in the back corner).
    Just pour it back into the reservoir when you're done.
