Prius Gen 2 a/c blower blockage?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OxfordPrius, Aug 12, 2016.
  1. OxfordPrius
    OxfordPrius Junior Member
    Today the flow rate of the air out of the vents on my Prius has noticeably dropped.
    It makes no different which vents I select (front, feet, or windscreen).
    The blower seems fine - it's still making its normal noise.
    The air still blows out nice and cold, there just isn't much of it coming out, even on full blast.
    I've pulled the cabin air filter and checked it's not clogged, so it seems like there must be a blockage downstream of the blower.
    Does anyone have any experience/ideas?
  2. JC91006
    16,482
    8,399
    which vents are affected? Can you notice the difference from low speed and high speed settings? You can see the operation of the blower fan with the cabin filter out, see if it's spinning faster at the high speed settings
    49,470
    could be the fan speed ecu.
  4. Mendel Leisk
    38,718
    Hopefully, not:
  5. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,136
    1,576
    Iowa
    How did Bisco get in there....
    But, seriously, probably already checked, but at times, lots of leaves, debris cover over the intakes along the bottom of the windshield on the outside of the car. You can open the hood and vacuum all that stuff off.
    Mendel Leisk and bisco like this.
  6. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    This seems to be an ongoing problem with the gen 2. My blower fried two months ago. It would occasionally turn on if I hit a bump in the road.:ROFLMAO:
  7. Fakhar87
    Fakhar87 Junior Member
    28
    Pakistan
    Four Touring
    Dear all i have bought 2007 prius 2 days ago. I have encoutered a problem relating to air vents.whenever i try to shift from face air vents to floor or windshield air vents the only air comes from the front air vents and also turning on the defoggers both windshield and back mirror no air comes out from their corresponding air vents. Someone told me that it is a most common problem with prius gen 2
  8. dolj
    dolj Senior Member
    7,651
    3,862
    Wellington, New Zealand
    I don't know about a most common problem, but it is a known fault. It is to do with the failure or incorrect operation of the servo motor(s) that control the air direction flaps.
    Unfortunately, depending on which are involved, can be difficult to repair.
