Prius gen 2 Death triangle randomly appears
Discussion in 'Gen 2 Prius Technical Discussion' started by StillKedar, Jan 22, 2025.
  1. StillKedar
    StillKedar New Member
    Australia
    i-Tech
    Hi Gurus,
    Prius iTech 2004 (Australia)
    I just did the hybrid battery reconditioning and I am pretty sure all the cells are healthy as I did a 2 min load test on each cell and then paired them correctly. However there seems to be a weird issue happening.
    Issue : If I drive without cruise control or turning the aircon on, it drives perfectly no codes at all. However, If I turn on either of them, then after I drive for 10 mins it gives me death triangle and the code on OBD scanner says P0000 & P3021. And when this happens the hybrid battery fan starts running as well as Engine starts running too and fuel consumption shows 99.9L/100kms. Even if I park the car the engine still keeps running and show that fuel consumption rate.
    I initially thought the inverter coolant pump is dead so I replaced it with a new one, also did the bleeding and coolant top-up. Then I thought MAF sensor could be playing up so I took it out gave it a nice clean with MAF cleaner, It didn't look dirty at all it was super clean as is. Even after this the issue still occurs.
    My guess - Hybrid battery fan 'Plug' malfunction. Could it be possible? I saw on YouTube a guy mentioned even after replacing the hybrid battery with new one, the code was still flashing and then a Toyota engineer bypassed the connection of hybrid battery fan and that fixed the issue.
    Attaching the Hybrid battery monitor report from Dr.Prius app while I was driving. No issues occurred as I didn't use Aircon or Cruise, but if you can look at the report and let me know if something looks suspicious.
    Any help is appretiated!
  2. Tombukt2
    Tombukt2 Senior Member
    13,448
    2,418
    Durham NC
    Take a look at your hybrid battery fan plug in the back right rear quarter and see what you got We got a lot of corrosion there a complete pin missing something you can just jump the wire across the plug and solder and tape it in or whatever you want to do for connection and that should take care of that if that's what's the problem that's a pretty easy fix A lot of people here in the States have to do that because they catch it too late and then you can push that plug and the new connections you made further in to the body panel and it'll be out of the way of future leaks water whatever seems to work well here anyway we get quite the rainy season.
    StillKedar likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,410
    968
    South Central PA, USA
    Your problem is not the hybrid battery fan connector. From your data that was collected, you have weak battery modules in block numbers 10 and 11. The battery modules should be replaced.
  4. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Error code P3021 indicates a malfunction in the 11th pair of cells of the high-voltage battery. The data you provided shows that the nearest pairs of cells have a large difference in voltage.
  5. StillKedar
    Australia
    i-Tech
    I don't think so as I have made sure all the cells are good and paired as per resistence. take a look below my load test. Also I am attaching the battery report of silver prius, I have 2 of them. The silver prius battery report shows similar -ve figures but it doesnt has any issues.
  6. StillKedar
    Australia
    i-Tech
    I dont see any plus apart from the one which directly connects to the fan i believe this 2004 prius has different plugs compared to my 2006 prius itech. Check the pictures thats the only plug i got.
  7. Tombukt2
    13,448
    2,418
    Durham NC
    That's the wrong plug look above the black piece of ductwork coming out of the center of the white fan right above that elbow You see that white connector with the black tape wrapped around it that's the fan connector for the hybrid battery undo that tape and look at the ends where the wire goes into the white portion of the plug or receptacle You're looking for green flaky crust that builds up from battery leaking and that kind of thing or corrosion on the pins etc now pulled the plug apart or you can measure the The voltage going through the plug and coming out the other end Is that happening on and on and on this plug is a known trouble spot it looks like this one may have been dealt with before your car looks very clean in this area I don't see any traces of common water ingress hanging out in the 12 volt tray but I can't see really well in the 12 volt tray usually that will be rusty on the floor of the 12 volt tray indicating water has been there and the rubber plugs have never been pushed through on either side and they need to be.
  8. Brian1954
    2,410
    968
    Look at the data that you provided in post #1.
    The battery block resistances for blocks #10 & 11 are in the 30s, and all the other battery blocks are in the 20s.
    What is important is the voltage difference between the battery blocks during hard acceleration (high positive amperage) and hard regenerative braking (high negative amperage). Look at line #128 and you see that the highest battery block is #11 at 17.93 volts, and the lowest battery block is #9 at 17.39 volts. That is a voltage difference of 0.54 volts. The battery is seeing 95 amps of regenerative braking.
    The four modules that make up block #10 and #11 are weak, and they need to be replaced.
    Do another data run and try to make the red triangle (master warning) light come on. You will find that the voltage difference between the lowest and highest battery block to be even higher than the 0.54 volts seen in line #128.
    If you have a scan tool that is capable of reading freeze frame data, you can look at the battery block voltages when the error code is activated. Then you can see exactly which battery block caused the trouble code, like the code P3021 (block #11) as noted in your post #1.
    #8 Brian1954, Jan 27, 2025
