Prius Gen 3 JBL Green edge wiring diagram for subwoofer
Discussion in 'Gen 3 Prius Audio and Electronics' started by Snz, Dec 4, 2021.
  1. Snz
    Snz New Member
    Auckland
    Technology
    Hi All,
    I have just got a new subwoofer and mono lock amp is like to install in my Prius.
    I have searched the forum and found the pinout/connector on my gen 3 2012 prius with JBL and navigation has a different pin out to most posted on here.
    could someone please tell me exactly which pins I need to tap into to get a full range signal?
    I presume it is the rear left and right channels.
  2. Snz
    Snz New Member
    Auckland
    Technology
    Nevermind.
    Have figured it out using a multi meter and the continuity function.
    My amp only had two connectors and not three like most gen 3 prius’ on here.
    I have labeled the the pins for rear left and rear right as these are full range I believe.
    The top row closest to the seat is the positive terminals.
    Khawailad and ASRDogman like this.
  3. April Staines
    April Staines New Member
    Australia
    2014 Prius Plug-in
    Hi. Would this happen to be a Japanase Prius PHV import? I have the same amp in mine and I would love to see a proper wiring diagram for this model.
