Prius Gen II 2006 needing new hybrid battery @ 96k in UK
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriUK, Jun 28, 2016.
  1. PriUK
    PriUK New Member
    Suffolk, UK
    I have a Prius Generation II (2006, 96k miles) that has recently suffered from the red triangle and VSC warnings, after loosing all power and limping home. The code reader revealed the codes P0420, P0a80 and P3013.
    I took the car to the local dealer in Ipswich (UK), who claimed to be able to diagnose the problem in 30 minutes for £59 and that it was very unlikely to be the hybrid battery. After taking half the day, they said that they would need another 30 minutes (and another £59) to confirm the issue.
    After nearly a full day, the dealer confirmed that a module within the hybrid battery had failed and that a whole new battery would be required (£1,068 plus labour). They went on to say, that it was possible a new Hybrid ECU would also be required (£723 plus labour), but that they could not confirm this until they had changed the battery. Labout charge estimated at around £450 worst case.
    Does this sounds reasonable? Not only the £118 to diagnose the problem initially - but the fact that the vehicle requires a new battery at <100k miles and that a new ECU may be required, but that they could not confirm until the battery had been replaced.
    To add insult to injury, the dealer suggested that I may like to take £200 scrap for it - despite the fact that I have just paid out £700 for a reconditioned cat (none main dealer).
    I asked if the dealer would be prepared to approach Toyota about a goodwill gesture - but they refused, stating that the warranty was only 5-years.
    I should add that although the car had main dealer servicing for the first 5-6 years, a local garage has serviced the car since. I was not aware of the Hybrid Battery Check program until this incident occurred and I started researching about the hybrid batteries. I would argue that Toyota had a duty to inform me about the program, as they had done about an earlier recall.
  2. JC91006
    16,674
    8,519
    I thought the UK had a really good warranty......like "forever". You should contact our member "Britprius". He knows all about the warranty in the UK.
    PriUK likes this.
  3. PriUK
    PriUK New Member
    Suffolk, UK
    Thanks for the tip - I'll look him up.
    I believe that the UK has up to 11yrs or 100k warranty - but only if the vehicle passes the Hybrid Battery Check. I didn't know about this program until this week, when I started to look into the issue, having not been informed about it by Toyota.
  4. JC91006
    16,674
    8,519
    Yeah, I think that's the UK program. Britprius knows all about it. I think he says they'll extend it every year if you do the battery health check....so it's really a "forever" warranty if you do the check yearly.
    Or you can simply look at some youtube videos online about battery rebuilding yourself.....it's very cheap to do it.
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    They were just playing the odds given the "low-ish" mileage. P0A80 + P3013 is almost certainly a failed battery.
    118 is high, but within the realm of what is typical in the states. Battery failure can happen at any time. I have personally seen them at 90K. The codes are irrefutably indicating a bad battery (block 3 becomes weak).
    Highly unlikely you'll need an ECU.
    IMHO, he's probably trying to scare you into taking scrap for it, so he can do a little something on the side and get a Prius cheap
    Data Daedalus likes this.
  6. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Is this a Toyota main dealer? Or just some third party garage? Either way, it seems they've roped you in with a £59 diagnosis offer, then easily doubled it in the process, before trying to scare you into parting with your Prius as scrap - on the basis that, by their own doubtlessly overinflated estimates, the vehicle will need "everything including the kitchen sink" replaced.
    For starters, the Hybrid components of the Prius II are guaranteed for 8 years in the UK, not 5 years. So, they're lying to you already.
    The HV traction battery may well have died due to only one of the smaller battery cells within dying. There is no reason why the ECU would die as well, so that's another porker.
    Basically, I'm suspicious. I see a dealer who wants to give you £200 for your vehicle, fix it super cheaply (because it might NOT even be the Traction battery at fault after all), and then resell your Prius for a fat profit of at least £3,000.
    I may be wrong, but, I'm "oh so suspicious".
    They've taken your car apart, so you can't go anywhere else. If you do want to fix your Prius, they'll milk you for every penny you've got, by claiming everything under the sun is wrong with it - even though that's more than likely untrue.
    I'd say seek a 2nd opinion, even if you have to tow the car somewhere else. Find a specialist who is prepared to fix the vehicle without scalping you in the process. A replacement HV Battery in good condition from a scrapyard could be as little as £500 - £750 if from a late model that had been written off and broken up. The ECU might be no more than £200 from the same source.
    An independent specialist (as in ex-Toyota mechanic who knows Prii) would get your Prius up and running again without trying to rip you off so shamelessly.
    Sorry if I'm wrong, but these are my thoughts.
    Prii, especially the 2nd Generation are over engineered. They don't break down that easily. Check Autotrader and you'll see Prii with much greater mileage than 96k on them for sale - all more than likely on the original battery.
    The only reason the HV battery might have died at all, would be the battery cooling vent / fan duct got blocked by something (dog hairs, assorted fluff and thick clogging stuff). The batteries do not normally overheat in the UK's temperate climate.
    During the summer, I use my A/C as even this cools the battery during operations - the cool air from the cabin is sucked down a vent and blown over / around the HV battery, keeping it cool.
    I hope this helps. Apologies if I got anything wrong here. Anyone who knows better, please assist, and correct me where necessary :)
    Good luck!
    iPhone 6s +
    #6 Data Daedalus, Jun 28, 2016
    Hasan likes this.
  7. PriUK
    PriUK New Member
    Suffolk, UK
    Yes, this is the Toyota main dealer!
  8. Data Daedalus
    1,025
    1,185
    Wembley, London
    Please seek a 2nd opinion, and do name and shame them, so they can be avoided by other Prius owners on here.
    iPhone 6s +
    Hasan and bisco like this.
  9. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Not quite, JC, the program is up to and including the tenth birthday, not forever. So, in effect, the coverage can last until the end of the tenth year - effectively 11 years coverage.
  10. JC91006
    16,674
    8,519
    Thanks for the clarification. I wasn't really sure about it......that's why I suggested he contact Britprius. I was going off my fuzzy memory of 1 additional year warranty, every year you do some type of inspection.
  11. dolj
    dolj Senior Member
    8,217
    4,187
    I think the new battery price (£1,068 plus labour) is very reasonable, but the labour charges are a bit on the high side. Having said that £450 is not outrageous.
    As far as £118 for the diagnosis fee is concerned, that should be deducted from the completed job if you chose to have them do the work.
    If you can afford it and you are keeping the Prius for a few more years, I'd be inclined to repair the car. You will certainly get more than £200 if you do decide to on sell it at a later date, with this repair is done.
    In the unlikely event it does turn out that you need a new HV ECU, you can source a second-hand one from a scrap yard for a lot less than the new price.
    I hope that helps.
    #11 dolj, Jun 28, 2016
    Data Daedalus and JC91006 like this.
  12. JC91006
    16,674
    8,519
    Definitely don't scrap the car for 200 pounds. Even if you sold it privately, you should get way more than that.
  13. Hasan
    Hasan Junior Member
    61
    The warranty for the hybrid battery is 8 years or 100,000 miles, whichever comes first - certainly not the 5 years they led you to believe! I would be very wary of this dealer, as already mentioned above, considering how many times they seem to be trying to rip you off.
    You might have had more luck with regards to a good will gesture, had you had your car serviced at Toyota, but since that hasn't been the case for the last few years, it does seem quite unlikely Toyota would do anything now unfortunately.
  14. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    New battery for £1,068? That doesn't add up nobody is getting a new battery for under $2000 USD ! (£1500 British pounds)
    Maybe china junk or trying to rip you off by fixing the 1 cell.
  15. Data Daedalus
    1,025
    1,185
    Wembley, London
    I'm not sure how much a brand new traction battery for a 2nd generation UK Prius would cost - does anyone know the exact price as at now?
    And, yes stockdaddy, talking about China junk, I vaguely recall reading somewhere that some Prius 2nd generation vehicles were built in China under license, for the Chinese market exclusively (up to 2011). Does anybody know if this is true - or am I hallucinating . If correct, that means the Chinese might be producing Prius II spare parts.
    They might be a lot cheaper than the originals....though, there might be a question mark regarding the quality
    iPhone 6s +
  16. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Not bashing China but as i recall there was some fake oem Prius cells that were made in China that didn't use the Panasonic cells.
  17. Data Daedalus
    1,025
    1,185
    Wembley, London
    Of course not. And neither am I. I actually own a Chinese made Pedelec Bicycle, which I'm rather very pleased with indeed. However, I was aware of what I was buying, and based on acceptable reviews from previous buyers, went for it.
    Some stuff from China's of rather very high quality indeed. Like the iPhone 6s Plus I'm typing this on, and a ton of other electronic equipment at home. Unfortunately, some stuff can equally be of somewhat.....questionable quality too. And that's what I'm worried about.
    iPhone 6s +
  18. sorka
    sorka Active Member
    1,017
    197
    Merced, CA
    2019 Prius
    The P0420 has nothing to do with the battery. That is your cat is not working at the required level. Since you just paid 700 for a reconditioned cat, you need to contact whomever sold you that cat and get your money back or have them replace it again. I just reconditioned my own cat after driving around for a year with a p0420 with a $20 acid bath saving me $1800 from buying a brand new one. Have almost 3K miles on it so far without the P0420 returning.
