Prius Gen III Torque data only refreshing once every 5 seconds, what's wrong?
Discussion in 'OBDII Android App' started by hybridbear, Feb 26, 2014.
  1. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    I have Torque set to log data every 1 second in our Prius. However, Torque shows the same data repeated five times and only has new data once every 5 seconds. The "Realtime Information" section of Torque behaves the same way. We do not have this issue in our Fusion Hybrid. The data there refreshes every second. I have the OBDII wifi scanner plugged directly in to the port. Although, the results are the same when I have it plugged in to a splitter cable with my ScanGauge plugged in to the other end.
    Am I logging too many parameters? In the Fusion I am logging about 20 parameters. In the Prius I am logging about 25 parameters.
    What's wrong?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Yup, logging slows down for me. Start simple and ramp up.
    hybridbear likes this.
  3. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    I'm surprised that logging would slow it down but still transmit data to the ScanGauge which appears to still refresh every second. I will test with less parameters.
  4. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Bottleneck may be your phone/tablet processor.
  5. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    I reduced the number of PIDs to 14 and this time it sometimes repeated the same data for 5 or 6 seconds in a row and occasionally would change each second for 2 or 3 seconds in a row. This is quite odd...I don't know if it's the tablet since it tracks 15+ PIDs from the FFH with no issues at a refresh rate of once per second.
  6. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    What baud rate did you connected with? How about with FFH?
    I have only logged about 5 at a time so 14 still seem fine.
  7. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    What is baud rate? I'm not very familiar with all the settings in Torque yet. Thanks!
  8. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    In Vehicle Profile, the bottom option.
    I think the default is to auto detect. I manually set mine to ISO 15765-4 CAN (11bit 500k baud). There is also an option for 250k baud but that's slower.
    Also under OBD2 Adapter Settings, is "Faster Communication" option checked?
  9. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Thanks! I appreciate the fact that you're quick to help! The default must be "Automatic - thorough protocol scan". That's where mine was set. I will test the ISO 15765 that you mention today to see if it makes a difference. There is also one called "Automatic - fast protocol scan" which I may try at a later date.
    I do have "Faster Communication" checked and I checked the "Don't calculate MPG/fuel" to speed up data retrieval.
  10. vvillovv
    vvillovv Senior Member
    3,664
    1,293
    NY
    are you using a splitter for the elm and scangauge?
    I've read here, maybe you've seen the posts to,
    some plugs seem to be probelmatic.
