Prius Gen3 P0A80 can I continue to drive on gas endlessly?
Discussion in 'Gen 3 Prius Main Forum' started by Nir44, Oct 18, 2022.
  1. Nir44
    Nir44 New Member
    Israel
    Hello my prius gen 3 have a battery hybrid malfunction I would like to know if I can continue to drive on gas only for 1 or 2 years ? (Without replacing the hybrid battery)
    51,774
    unfortunately, the hybrid battery turns over the engine to start it. at some point, you will have to repair/replace
  3. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    And you would have hardly any acceleration since the electric motors provide the torque necessary when speeding up and going up hill.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The P0A80 code allows the car to continue to drive normally. Once the car decides which of the individual modules is failing, it will provide an additional code, and will put the car into limp mode. People have continued driving for many months merely by resetting the code as needed. The code may clear short term, but the problem doesn't go away and will continue to get worse until the time comes that it can't be reset.
  5. Nir44
    Nir44 New Member
    Israel
    What is limp mode ?
  6. Nir44
    Nir44 New Member
    Israel
    What do you mean turns over the engine isn't that the role of the 12v battery?
  7. bisco
    51,774
    not in a prius. the 12v only boots up the computers and closes relays to make the car 'ready'. the eCVT is connected to the engine and the hybrid battery powers the electric propulsion motors to spin the engine countless times as you're driving.
    mollymudpie likes this.
  8. CR94
    CR94 Senior Member
    2,685
    1,164
    Northwestern S.C.
    Huh? As far as the context of starting the engine while the car is parked, that happens when the hybrid battery powers one of the two electric motors to crank the engine. (Starting the engine while the car is rolling with engine stopped is a little more complicated.)
  9. bisco
    51,774
    exactly
    m.wynn likes this.
  10. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Explanation without the white lab coat with protective googles on...the hybrid battery starts the gas engine. Once the hybrid battery is dead, you will no longer be able to start the car.
  11. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    When you try merge on to highways and slam the accelerator, you’ll be smooth sailing at 25 mph and no faster. At least you’ll be saving a lot of gas.
  12. sharpdoug
    sharpdoug Tig
    If you’re keeping the car-I just replaced the NiMH battery with the Li ion from NeoPower. Way cheaper than the Toyota NiMH and comes with a 2 year warranty. Better acceleration and better fuel mileage simple installation and half the weight. I’m only suggesting this because driving on the engine only seems like a bad idea.
  13. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    eventually your bad modules will have a thermal event. maybe just a simple melt, or a little fire, or maybe an explosion. keep us posted
  14. ammdb
    ammdb Active Member
    277
    111
    Indianapolis
    Limp mode happens when a fault (like overheating due to unbalanced modules) causes the car to give up on the main traction battery. When this happens the gas engine revs constantly to generate the electrical power that otherwise would be coming from the battery. It's like the little donut spare tire, good enough to get the car in to be serviced, but not intended for normal driving.
    #14 ammdb, Oct 29, 2022
  15. royrose
    1,389
    953
    Foot of Pikes Peak
    The guy is in Israel and wants to keep going at a low cost for a year or two. While replacing cells or a putting in a "reconditioned" battery is not ideal, in this case it might be the best choice.
