Prius Gen3 PHEV Comparison Chart
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by linuxpenguin, Aug 18, 2010.
  1. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Hey guys,
    So I finally got around to pulling my comparison of Prius Gen3 PHEV systems (both aftermarket and OEM Toyota) together and compiled it into one spreadsheet for easy viewing. I came across a bunch of posts asking if such a list for the new Gen3 Prius existed, so...
    I added in a bunch of calculated values that may or may not be exact. Since some of the systems in the list aren't officially released yet some of it is speculation (but educated speculation).
    Here are a few more disclaimers before the link at the bottom:
    1) I tried my best to make it fair and unbiased. The information on the mentioned conversions I have pieced together from data I have gleaned on these forums or the conversion companies respective websites / press releases. Additionally I have had the opportunity to actually analyze in depth a few of the batteries used in said conversions (where some of the more technical numbers come from).
    2) I do not mean to offend anyone--so please, do not be offended.
    3) I only included commercial systems that come with a warranty of some variety. This list does not include DIY kits or systems because there are simply too many variables in how you do them to make a fair or realistic comparison.
    4) I chose to make it un-editable to the public not because I believe I am 100% impartial but because I did legitimately try to make it a fair comparison in the first place. For those of you who have had experience with the mentioned PHEV systems please feel free to let me know if I've made a grievous mistake but I think the information is pretty accurate. All I ask is that you provide /constructive/ information rather than just flames.
    5) To the best of my knowledge, the information in this comparison is accurate--but please don't bite my head off if I made a mistake.
    6) Yes, I know some systems like Enginer offer different larger configurations now--I chose to only include the 2kwhr and 4kwhr because it is my understanding that larger configurations require somewhat...unique...mounting methods that may or may not be universally acceptable and / or safe for the average end user. Just do the math if you want to see how a larger system would compare--most of the values scale linearly.
    7) Note that there are three separate sections to the spreadsheet covering different aspects of each conversion system--each section has its own set of foot notes.
    8) Please read the foot notes before complaining or reporting an error--chances are there is a good reason why something is the way it is.
    9) I deliberately left off estimated MPG expectations since we all know your mileage will vary heavily based on how far you drive and how often you plug in. There really is no magic formula for determining what mileage you'll get (unless you always use EV mode :)).
    10) At time of writing, two of the systems listed (Toyota & PICC) are not yet commercially available thus a release date is also not yet available. You'll have to contact those companies directly for more information as to when the system will be available for general purchase.
    LINK TO GEN3 PHEV COMPARISON SPREADSHEET:
    http://spreadsheets.google.com/ccc?...EFjb01HLUszb3dOMlllZkE&hl=en&authkey=CLDypaYG
    Andrew
    11 people like this.
  2. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    144
    Fort Worth, TX
    Thanks for making this. I'm at a loss to comprehend why toyota's own modifications weigh about the same, but only deliver 3.5Kwh of capacity. Why is it that other aftermarket upgrades can fit more capacity into the same space and weight?
    The real comparison will come with Toyota releases pricing information on the PHV version. Will the extra cost be worth it compared to an enginer kit? Or, on the flip side, if the cost is very affordable then it might bring down the price of the PICC kit and others.
    Being that the Chevy Volt is being priced at $41,000 I would hope Toyota would be able to get this car under $30,000. I would also hope maybe they could squeeze about double the range into it. 25 miles would be a lot more useful to people.
  3. linuxpenguin
    352
    182
    It depends on the batteries used--some are much lighter and significantly more energy dense than others. The official weight for the Toyota battery system is an educated guess based on the technical specifications and reported weight distribution--can anyone confirm or deny it?
    Yup, no pricing available yet on the PICC system as far as I know. It will be interesting to watch.
    I agree, but I'm not sure how Toyota can cram much more than they already have...their current batteries take up so much space already I'm not sure where they'd put the extra batteries. The only way I see that happening is if they combined all three batteries into one and got rid of the "sustain" battery all-together. Even still you'd be pushing it for a 25 mile range with their current setup...
    Andrew
  4. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    You should add more info that the Toyota system can do:
    - A/C runs as heat pump so you can use heat without ICE
    - Run with ICE not spinning up to 62mph
    The PICC system on a Gen II car spins the ICE over 43mph (no fuel) .. unsure about this behavior on a Gen III Prius.
  5. Tideland Prius
    16,155
    Toyota charge time is 3 hrs on 110V in the demo model with a 14 mile range (i thought this was advertised)
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    I thought Enginer is CARB certified. In the site, it says to add $1000 for CA CARB
  7. linuxpenguin
    352
    182
    That's different actually. CARB requires a longer and more detailed warranty on the battery system / emissions related parts in certain states (California, New York, etc) thus they charge an extra $1000 to comply with those requirements.
    CARB certification means it needs to be tested in a federal laboratory for emissions and fuel consumption to make sure it doesn't increase emissions beyond that the OEM vehicle (which believe it or not some conversion systems actually do significantly increase emissions due to failing to let the catalytic converter warmup properly before going into EV mode). Certification also involves an extended durability test to ensure product longevity as well as some other steps.
    This procedure must be redone for every vehicle the system is designed to be used with. It also needs to be repeated if they make any major changes I believe.
    Andrew
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    OEM PHV Prius has 5.2 kWh battery pack. The plug only consumes 3.56 kWh of energy.
    The capacities provided for the other 3rd party plugins are the maximum capacity of the battery pack; not the energy the plug consumes.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I was of the impression based on our visit w/ Toyota that the rear springs on the PHV were indeed upgraded.
  10. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    The EV mode speeds need to be altered, on gen3 they are 45mph for low speeds EV, and 21mph and 30mph for full EV mode before and after warmup.
    it's also very easy to stay in the EV half of the HSI with gen3, so i think you should put some calculated ranges in the Enginer section - with a caveat that you may not be able to hold that speed for the whole range (i.e. you need to stop/slow down at some point to reach that range)
  11. linuxpenguin
    352
    182
    Here in the US the EV mode speed limits are 11 mph and 25 mph once the ICE is warmed up--since most of the people here are likely viewing from the US I figured I'd put the US figures for it.
    I didn't calculate EV range for the Enginer system because the system doesn't officially pursue it (especially in the Gen3 model year). I suppose I'm coming from the perspective that stealth mode (that is, keeping the ICE off by playing the "keep the HSI under the median" game) isn't really EV mode in the traditional sense...There are far too many variables to get an accurate estimate for "stealth" range I'm afraid. The spreadsheet is designed to give "real-world expectations" under normal driving for the various systems.
    Andrew
  12. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Everyone,
    Thanks to Andrew for the data.
    I think that one thing to realize is that, today, Enginer is the only system available for the Gen3. All the others are still in development. The reason for this is the same reason that Enginer does not officially pursue EV. That is Enginer does not reprogram or spoof any Prius programming. This has the plus of working in new and different vehicles and the minus of not being optimized for EV.
    Thanks again,
    Dan
  13. cproaudio
    2,401
    759
    CA
    One draw back of PHEV systems that pursue maximum EV is that it goes into EV mode as soon as you turn on the car and not allowing for the engine to warm up thus increasing emission. I don't think the Enginer kits do that. It goes into engine warm up as soon as you start driving like a normal Prius. If this is the case, doesn't it higher chance of obtaining the PZEV-SULEV and the CARB certification?
  14. dan2l
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Enginer states that they have conducted EPA FTP 75 emission test and the result indicates reduction of the CO2 emission (in half) and no extra amount of other emissions. This was done with no changes or spoofing to the Prius computers. Enginer is working towards certification but I expect it is still a ways off.
    Thanks,
    Dan
  15. linuxpenguin
    352
    182
    Any links to more information (eg: where/when was the system tested)? What model year Prius was the test performed on (it must be certified for every vehicle it's installed in)? Was any sort of EV mode used during the test (system must be sold exactly as-tested in order to maintain whatever emissions certification earned)?
    CO2 emissions reduction would make sense though a cut in half seems a bit of a stretch considering the nature of the test but I suppose it's possible. It's the other regulatede emissions I would find most interesting.
    If no EV mode was used on the emissions test (which is what I suspect) then there should be no problem passing emissions testing (I would be shocked if it failed since it's basically just a stock car w/ some extra electric juice). The problems come up when a system uses EV mode which significantly interferes with the vehicles catalytic warmup procedure during the test.
    CARB certification requires more than just passing emissions testing though, it also requires a system durability test and supposedly a rigorous revision process (documenting changes and methodologies and the likes). The actual testing phase is a good chunk of it though.
    Andrew
  16. adric22
    642
    144
    Fort Worth, TX
    I'm not sure I agree with that statement. For 2 reasons:
    • If you are able to make it to your final destination without the gas engine ever starting, then you have saved a lot of emissions.
    • The engine will have to come on and do a warmup cycle anyway, every car does. Have you ever noticed that when your prius I.C.E. starts for the first time (whether sitting in your garage or already going down the street in EV mode) It actually continues to draw almsot all motive power from the battery pack until the engine has warmed up some. So even though you are moving, the engine isn't supplying much power at first.
  17. HTMLSpinnr
    5,339
    917
    251
    Regarding your second point - in the Toyota Prius PHV, the engine will not start at all with EV available unless the following occurs:
    * Accelerator pedal exceeds 80% (in Eco) from a stand-still - less at higher speeds (i.e. you break out of the EV only range on the HSI)
    * 1.6 miles remain in EV range and the engine has not yet started previously (or if it has, coolant temp is too low).
    * You exceed 19 miles of constant, pure EV driving - the engine will start to lubricate certain PSD components.
    For shorter EV trips, the engine never starts. I validated this with multiple 5-10 mile trips.
    Also worth noting, albeit slightly tangential, the 2010 Prius will also skip or delay the initial warm-up cycle on hot summer days unless SOC or A/C demand warrants.
