Prius goes off the deep end...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nannyandnutro, Sep 11, 2004.
  1. nannyandnutro
    nannyandnutro New Member
    71
    Minis Tirith, TN
    I posted this a couple of other places. I need some input on what I should do/say to handle this situation. Here goes:
    Last night, driving home I had one solid bar left on the gas gauge. As I traveled up an incline, the bar began flashing and the "add fuel" message popped up. Fine, but things went very bad from there.
    I was a mile or so away from home but pass four gas stations on the way. Before I could even contemplate filling up, the hybrid warning light came on followed by every other light on the dash. I then lost considerable power and watched as the speedometer sort of counted down. I couldn't even make it to a part of the road with a shoulder before the car simply "seized" and wouldn't go further.
    This all happened over a few hundred feet. Sitting in the middle of the road just past a blind curve at 10 p.m. was rather daunting, but fortunately roadside assistance had a truck there within minutes. At this point, I figured something wacky had gone wrong with the computer and Toyota could just reset it and all would be well.
    The tow operator couldn't get the car into neutral. We looked everything up in my manual just to be sure, but no such luck. He put it on dollies and towed it away. First thing this morning, I called the service dept. and was told that a) it probably wouldn't be fixed under warranty and B) they had no Prius tech until Monday so they knew nothing other than that I'd been negligent and let it run out of gas.
    :cussing:
    He even tried to argue that since they were unable to determine if my issue could be repaired under warranty that I was ineligible for a loaner car. Luckily, I contacted my salesperson who slipped me a Corolla (a surprisingly nice little car, by the way) while they sort this out.
    I guess it comes down to this: we know for a fact that there is gas in the car. Upon lifting it onto the truck bed, the second tow operator said he could hear it in there. Even if the gas tank were empty, I had no previous indication of such, so how could that be construed as my fault? The behavior of the car in general during all this tells me there's something else going on. I could tell from my conversation with the service advisor that they want to wriggle out of this if possible. The man even started quoting me diagnostic fees I would be responsible for. There was never an apology or sympathy, just blame and uncertainty. Has this happened to anyone else and how were you treated? What was the outcome? I have noticed at oil changes that most of their employees don't even know how to drive the car into the service area, so there isn't much confidence there. I guess any info you all can throw my way is appreciated. I'll be biting my nails all weekend (and driving the bejesus out of this pretty new Corolla).
  2. jamarimutt
    jamarimutt New Member
    985
    If there's gas in that tank it should not be your fault that the car "ran out of gas" because it did not. Something else is at fault.
    However, if there's no gas in the tank you may be in trouble. The Prius gas gauge is notoriously unreliable, to the point that Toyota is authorizing a rather complex fix for owners who formally complain about this (this may be the moment to do that). For now on keep track of your mileage to be sure that this does not happen again. My car went once from two bars all the way to one blinking bar.
  3. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    There is always a little gas left in a tank, even when you think it is bone dry... which leads to a trick I learned back in the 80's. Violently sway the car back & front to slosh that gas out. You can squeeze out enough to get yourself out of harm's way.
    Of course, I have no idea if that would ever work in a Prius since it has a bladder... and I haven't ever tried... since I use mileage as my secondary gauge. That "9 gallon" rule will keep you out of trouble... which leads to the TSB available. If you actually ran out of gas without exceeding that threshold, have that work done. It will fix gauge accuracy.
  4. nannyandnutro
    71
    Minis Tirith, TN
    I checked and my VIN doesn't fall under the fuel gauge TSB. I've only had the car since April and it was manufactured in March. That morning, I put around 3 gallons in (I'd forgotten my check card) and according to my MPG I'd have gotten just over 150 miles out of that. According to the odometer, I was a hair over 100 when this incident happened. Not that I was relying on that, but the bottom line is that my gauge was not blinking at all, and in an instant it started blinking and the car was dead within a minute. That's my issue. And the sloshing trick? You brought back memories of my Eurovan before I fixed the broken gas gauge. I was relying on quick calculations but was unaware that my husband had taken it out earlier that day. It began to sputter during my commute, we pulled that same trick and got to a gas station just barely. Ahhh, fun stuff. This situation, not so fun. BTW, if it helps mine has just over 13k.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    What did you do to try to restart the car, and what happened when you did? Getting the car into neutral requires a "READY" state as shifting is purely electronic. Did the tow guy have any experience at all with a Prius?
    Several of us have experienced a similar situation of sudden loss of power unexpectedly. In most of those situations pulling over, shutting all the way down briefly, then restarting results in only the "Problem Triangle" being left and otherwise normal operation. 3 more cycles (or maybe just 2 additional) of shutting down and restarting usually clear that triangle.
    Did you try restarting at all? What were you doing to try to get the car in neutral and what condition was it in (i.e. Ready mode but no power, not in Ready mode, Ready mode but you didn't try to drive, etc.)
    Ok, the $100 diagnostic fee. No way should you pay it... unless you ran the car out of gas, which they should be able to prove...the car won't start, gauge shows empty, gas added, car starts fine. But pulling codes should not be a charge. And even if no codes are found that doesn't mean it wasn't the car's fault. When I had my "limp home mode" episode I took the car in within a few hundred miles and there were no problem codes at all found...but I can assure you the incident occured. A brief search at this site should find you several threads showing similar issues with no codes...print them out and take them to the service mgr. with you if they try to charge you.
    Ok, you want my honest opinion???
    1)Either you had the same "limp home" condition I describe above and it should be completely covered by warranty.
    or
    2) You screwed up and didn't have enough gas...probably a small miscalculation or something. I don't know if there might be a problem with inaccuracy of the fuel guage when it the tank isn't filled full when refueling and thus the very late "Add Fuel" indicator. That's pure conjecture.
    I hope, for your sake, it's the former and you prevail and have the problem diagnosed and treated for free.
  6. nannyandnutro
    71
    Minis Tirith, TN
    We tried restarting it several times...the ICE would kick in for a brief second, the dash would light up again, and the car would be inoperable. We never could get it into a "ready" position. Even in worse case scenario (out of gas) why would I be responsible for the gauge reading incorrectly? By that logic, on my Camry, when the orange light first comes on or the needle gets close to "E" I should stop the car immediately? I don't think that makes sense. Moreover, if it WAS out of gas (and I am 100 percent sure there is gas in that tank) why would the car do all of the strange things it did? I mean, even the truck driver said it looked possessed. At one point, when we were desperately trying to get it into neutral, the fuel gauge came on and showed full for a minute and then the whole thing began to flash (still showing full) I just want everyone to understand (especially Toyota) that I did not intend to drive it any further than a quarter mile to the gas station, but the car didn't even give me that chance. In that case, even if you figure only a 1 gallon fuel reserve and lowest possible MPG a quarter mile, or in my case, a few hundred feet-isn't too much to ask, is it?
  7. efusco
    19,891
    1,194
    Nixa, MO
    I guess that's a reasonable question to ask, and I agree that the guage should be fairly accurate and predictible. But, ultimately, it's the driver's fault if the car runs out of gas. Sounds like you were pushing your luck with that 3 gallons of gas instead of a full fill up.
    You haven't described the "strange things it did" or why the tow guy thought it seemed "possessed". Again, if that guy knows nothing about the Prius just about anything it does is going to seem abnormal to him. His statement, without further perspective (tows Prii on a weekly basis and has a solid understanding of the electronics of the Prius and how the electronic control of the 'gears' work, etc), is essentially meaningless.
    I'd like to hear more about the 'strange things it did' as that may help answer your questions.
    Again, given the scenario you should certainly have had much more reserve. But, as stated above, 'gas in the tank' does not equate to usable fuel in the tank. There will always be some reserve.
    If you have a chance, and the service dept. is still convinced your car died due to low fuel, try to be there when they fill it up....and make sure they fill it full and see how much fuel it takes...if it takes ~11 gallons then it was out of gas and your 'case' will revolve around convincing them that it's the guage's fault. If it takes less than that (like 9 gallons), then you have a good case to say that there was usable fuel in the tank and that something else caused the problem.
  8. nannyandnutro
    71
    Minis Tirith, TN
    So far as the strange things, one that stands out was this: I had my hazard lights on as well as the headlights just for visibility, but after a few minutes the right headlight wasn't on and the right hazard blinker both inside and out wasn't on either. The left counterpart of all these worked fine. Did my car have a stroke?!
    Also, when I tried to "reboot" the car, it would come on like normal, no warning lights, the ICE kicked in and started charging the battery according to the energy screen and then a second later it was gone again.
    The tow guy actually works for another local Toyota/Ford dealership and has towed several Prii as well as Insights. The very idea of "several" scares me because I've seen less than ten individual ones in the area since they came out. He said he's seen them do nutty things at times. He also told me that in the last two weeks they had taken 16 Ford cars off of the flatbed, brand new from production, with serious engine problems.
    We still don't see eye to eye on the fuel part. If I'd driven while the gauge was blinking even a mile or so, then I could accept the blame and move on. This isn't what happened. I should not have to calculate my gas consumption/refueling down to the last mile. This is why we have gas gauges, isn't it? I owned a cheap rusty car with that problem, not an expensive new one. :D It seems to me that none of these things should have happened as a result of running out of gas anyway. It looks as if some computer system has failed or become corrupted somehow. I have a feeling that regardless Toyota and I will be going around in circles Monday if the difficulty of getting a loaner car is any indication. I'll just make sure I bring the toddler with me to the dealership BEFORE his nap. :wink:
  9. richard schumacher
    7,664
    1,043
    United States
    Moral: don't screw around when you get to one bar. Fill the gas tank.
  10. efusco
    19,891
    1,194
    Nixa, MO
    From the description you've given I don't think the fuel is an issue at all...something's fried. Almost makes me think the add fuel warning you got had nothing to do with it at all, just happened to be the first 'symptom' of the disease.
    I think you're not understanding me on the running out of gas thing, I'm not trying to blame you and I agree that the car should accurately reflect the amount of fuel...but say something like that as a pilot and you'll get nowhere...it's the pilots job to know how much fuel is used and how much is in the tank. If a plane runs out of gas it goes down as pilot error...not a bad fuel guage error. But again, I think Toyota should've done a better job with a more accurate guage and I'm thankful that mine is getting 'fixed' soon.
  11. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    Actually, you can shift to neutral with the car not being in "READY". The tow operator did it to mine when it died, and I was suprised it worked.
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    Jonnycat26 is right. Foot off brake, hit power 2 times shift to neutral. Car moves, you can push it or tow it onto a slipdeck tow truck.
  13. efusco
    19,891
    1,194
    Nixa, MO
    RE: Neutral without "Ready"--thanks for the correction guys, my mistake.
  14. Frank Hudon
    4,147
    so now you can coast out of your driveway without using the EV button;)
  15. eak354
    eak354 Member
    447
    HI
    how many miles did you get or do you go for before filling up? i guess it's just getting to 'know' the bladder behavior. i've been filling up at 400 miles which has 1 bar and sometimes it starts flashing but consistently fill up 9 gallons +/- .3 gallons. so i know everytime i hit 400 miles i have a leeway of at least 2 gallons whether the last bar is blinking or not. but even with this knowledge, i try to avoid pushing it..
  16. nannyandnutro
    71
    Minis Tirith, TN
    In this particular instance, I went out to get dinner about 10 miles away on two bars. On the trip back, it went down to one as I entered the last stretch of highway and to me that meant "get gas at the next opportunity" I would say it was three miles of driving before all this happened. I always get gas when I have one solid bar left and it was my intention to stop at one of the several clustered near my home. In 13k miles, I've gotten to know the car very well and things have never progressed even close to this quickly. My MPG always seems to average 50.1 over almost every tank so I do think to get gas when I approach the 500 mile mark.
    If it were a regular car, no one would even think about filling up on the last notch before empty as an emergency measure...but that's what I'm being told about the Prius. Heck, there wasn't even a single gas station between where I went and the last quarter mile before home. Certainly, if my one bar had started blinking during the drive and all this craziness hadn't happened immediately thereafter I'd have pulled over to a safe place and walked that last little bit to get some gas.
    However, I've never heard of any Prius owner who "just" ran out of gas experiencing an inability to drive or really any of this. I know for sure that's not what happened but Toyota is already leaning that way. I'll fill you in on the details Monday.
  17. nannyandnutro
    71
    Minis Tirith, TN
    WHOA...I don't know if I had a momentarily lapse in intelligence when I first read the fuel gauge TSB but I just looked at it again and my VIN ending in 65098 indicates it does. Is this going to help my case?
  18. efusco
    19,891
    1,194
    Nixa, MO
    If you were out of gas then it most certainly will, and I think you'd be wise to have the warranty work done.
    Listen, I think you have a good 'case' regardless. What I suggest you do is sit down on your computer and type up, in WORD, exactly what happened in as much detail and in a flat and informative way. No noise about how upset you were or using the word "possessed" (unless you put it in quotes). Describe exactly how much gas you put in and when and exactly how far you drove and the exact sequence of events as they occured...esp. the odd hazard light flashing and other weird dash light flashing. Give a copy to the service manager, give a copy to the team leader taking care of your car to be placed in your file and put a copy in an envelope for your Prius Certified Tech. And keep a copy for yourself.
    If you know how to find the tow guy ask him if he'd write up a statement about what the car was doing for him to back up your story.
    You'll have made everyone aware that you didn't just panic when you ran out of gas by pushing the car too far. You'll make everyone aware that you have the event recorded, in writing. They know that that same statement can climb up the ladder, as needed, and that you are serious and not about to be pushed around.
    Ask them, without letting on that you know, if there are any TSBs out there on the Fuel guage. Ask them, also, if you need the LSC 40E...the problem that causes the engine to go into "Limp Home" mode...similar to what happened to you.
    Make sure they give you the exact DTC codes they pull off the car...a printed copy would be best.
    And hang in there. You'll get your due.
  19. Frank Hudon
    4,147
    also send a copy of the letter to Toyota Corporate HQ. The address is in your warranty manual. On the top of the letter include
    CC: service manager
    CC: warranty clerk
    CC: Prius service tech
    CC: Toyota Corporate
    the last one is the one that will get you the service that you need and deserve
  20. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    It is not, or SHOULD not, be unreasonable to expect the Prius blinking bar to be the equivilent of the "low fuel" warning light on other cars. It doesn't, or shouldn't, mean "car has 1 drop left, get gas NOWWWWW". I believe there is a separate warning on the MFD for that :)
