Prius Hates Heat ! (Extreme Prius Driving Part 1)
Discussion in 'Gen 2 Prius Main Forum' started by dianeinreno, Aug 10, 2012.
  1. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    So I'm in southern Arizona and the temps here have been 109-115 (Wth!) and my '07 does not like this. Two things that I noticed :
    1. When I start up in the morning I lose three to four bars of charge from when I powered down in the afternoon.
    2. My shift lever went wonky!!! It would not stay in drive or reverse and had to be held down in either R or D to stay in gear. An internet search revealed many reports of similar problems associated with hot days in 07 and 08 models. On closer examination what appeared to happen is that the shift lever would "catch" and not completely go back to it's "hand's off " position causing the car to go to neutral. After the aircon had been on for 15 minutes and the car cooled down this problem disappeared.
  2. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Good to know that others have had this experience with the shifter. Our 2005 did this one day when it was extremely hot outside and i thought to myself Wth?! I never got around to looking into it further and just wrote it off as a fluke, good to know it may happen again.
  3. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    From the number of reports I saw when I did the search this may well be a quaity control issue and worthy of a recall. Quite a few people mentioned that the dealership charged them in the $700+ range to replace the shifter with a couple of reports of the dealer giving the part for free but charging $300 for the labor.
    I've had the Prius since March and never had a hint of shifter difficulty until I apparently traveled to Planet Vulcan which appears to be located in Southern Arizona. It probably got to 125+ degrees inside the car since it was 111 outside.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Bet you do not have a Priuschat Windowshield shade nor tint. Bet you do not have the package shade extended in the back area. Bet the car was hot as hell. I like to bet.
  5. dianeinreno
    dianeinreno Member
    104
    17
    Denver,CO
    Today it was 113 again outside - inside the car it must have gone to 125+ (yes I do have a windshield reflector) . And once again the shifter began to "stick" and not return to it's default position unless I put it there manually. The effect is that the car stays in neutral unless I move the shift lever manually to the far right. When I get out of this terrible heat next week it will be interesting to see if the shifter problem goes away.
  6. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    It's got to be a defect --- I've had a 2004 for 8 years in Tucson and never once had a heat-related problem. Sure the 12V battery gave up the ghost, but no earlier than what others in cooler climes have reported. I would suspect that some plastic component is expanding in the heat. Sounds like you may be out of warranty so perhaps replacing with a Stage 10 ESS would be a cheaper fix: Stage 10 Electronic Shifter available now | PriusChat
    I think your title of this thread should better read: "My Prius...";
  7. You are running the AC full blast at coldest setting?
