Prius Heat Working Properly?
Discussion in 'Gen 2 Prius Main Forum' started by djasonw, Dec 10, 2005.
  1. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    As I understand it, the Prius has an auxilliary heater to augment initial heat. I don't know if it's my imagination, but it seem to take a long time to make my cabin completely cozy. Is it possible that the auxilliary heater is just not working? If I brought it in would the techs be clueless? After 10-12 minutes of driving the cabin starts to feel a little warm. My commute is only 15 minutes. Any thoughts???
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Both my 04 and 05 heats up to comfortable level in about 10 mins. When it really cold around 0 it takes a little longer and usually the fan always stays on high when it's that cold, but above 0 the fan usually starts to gradually reduce speed after about 10 mins., if you leave it do it's own thing and not override it.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I have heard, but can't officially confirm, that the auxillary heaters only kick in when the heat is initially turned on to MAX. Also, even when on, they are small and will provide only nominal warming.
    When the car is very cold (first start of the morning, etc.) it can, indeed, take a long time to get much heat. This is particularly true if your trip involves multiple stops. The other day I was leaving a conference I'd been at all day and the OAT was around 10 degrees. I'm able to monitor coolant temp. A solid 15 minutes into my trip home (maybe had gone 4-5 miles due to several stop lights) and the ICE temp had only reached 122 degrees. Although I could feel some heat coming out, it wasn't much.
    OTOH, when I'm at home or work I use my Engine Block Heater which, so far, has kept the ICE temp at at least 122 degrees BEFORE I start up. I'm usually up to 145 degrees within 1/2 mile and getting good heat output in just a matter of minutes.
    Thus, I conclude, that if your trip involves some fairly hard driving right away (ie Highway speeds), you'll probably get relatively quick heat thanks to the ICE warming up more quickly. Cold starts with frequent stops, esp. in the first 10-15 minutes of the trip and you're going to be getting very little warm air output.
    In case you haven't been following the Engine Block Heater thread, this is a mod I strongly recommend both for a gas mileage standpoint and a creature comfort stand point.
  4. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    p.s. just to say - Prius in my experience has the fastest cooling/heating system, out of at least any Toyota I have driven. Since it is all electrical, it heats up much faster than an normal heater/engine would...
  5. djasonw
    960
    121
    Coconut Creek, FL
    Thanks for the replies. Agreed the AC is the fastest cooling AC I've ever had. The heat is not bad, but ten minutes and low 20's can be a littly chilly. I guess last year it was different as my commute used to be 40 min. Now it's 15 min. I'll read the thread about the block heater, it may not be a bad idea.
  6. daniel
    14,487
    1,519
    Spokane, WA
    I drove my Prius in Fargo for one and a half winters. My commute was 10 to 12 minutes.
    That electric heater is only at foot level, and is too small to actually feel any heat out of. But my feet got comfortable MUCH sooner than in my old Civic, so I think there was some heat coming out of it.
    At 20 below zero I pre-heated the car for 5 minutes before driving, and after 5 minutes more (driving) there was enough heat coming out the hand vents to take off one glove at a time, hold my hand at the vent for a while, and then put the glove back on and do the same for the other hand. After 10 minutes of driving I could take my gloves off. After 20 minutes (on the rare long drive to the shopping center) the car was comfortable.
    Amost all the heat comes from burning gas. The Prius burns half as much gas as another car, so has less waste-heat output. I once drive a Camry. Now that car put out heat!!! But in every other respect my Prius was far and away the better car.
    In the end I left Fargo and moved here. The car heats up MUCH faster at 20 above than it did at 20 below!!!
  7. xbdude
    xbdude opticat
    168
    North Central Florida
    I'm still waiting on my Prius, but all of this seems interesting. I'm in Florida, so temperatures such as those mentioned in the posts will not even come close. Maybe there will be a few days in the high 20s or low 30s, but that's as low as it gets for the most part. My concern is how the AC works!
  8. jaguaraja
    jaguaraja New Member
    147
    Long Island, NY
    for anyone having trouble with heat:
    i have found that the auto setting it not always best. it start the heat flow from the feet. if you leave it like that it'll take about 10 minutes before the cabin warms up.
    screw auto and change the air flow setting to the vents that face you. the cabin will be warm in about 5 minutes.
  9. jeromep
    jeromep Member
    827
    Eastern Washington State
    I never lived in Spokane, but visisted it nearly monthly during my last year or two at WSU. Spokane is downright tropical compared to Fargo, especially in the winter. However winter fuel economy is effected by 2 things, warmup times and winter blend of fuel, which has less actual fuel energy than summer blends.
    As for effectiveness of the entire auto climate system, it is really quite excellent. I do find that when it it is very cold out the pause the system has before activating the fan and be a little annoying, especially when we are conditioned to have cold outside air running on us even in the dead of the winter as part of a normal cabin heat up process. But the coolant storage system really does help the car produce cabin heat more quickly than if it were not equipped.
  10. daniel
    14,487
    1,519
    Spokane, WA
    The whole climate system in the Prius is probably my biggest complaint about the car.
    Item: Some air will come through when the fan is off, but to change the temp, you have to turn the fan on. If you had the heat up in the morning, but you want it off in the afternoon, you must start the fan, then scroll down through the temps to cold, and then turn the fan back off. Otherwise, even with the fan off you'll get hot air coming out the vents. THIS IS STUPID!!!!!!!
    Item: You cannot jump from Max Hot to Max Cold or vice versa without scrolling through the entire range. THIS IS STUPID!!!!!!!
    Item: It ALWAYS defaults to outside air when you turn on the climate control. In cold weather (especially Fargo!) you do NOT want outside air until there's some heat flowing. You want to recirculate. It refuses to remember the last setting, so every time you shut off the fan and later turn it back on, you get outside air, whether you want it or not. THIS IS STUPID!!!!!!!
    I do not like automatic, because I don't want to waste energy running the A/C if I don't need it.
    My only other complaint about the car is that you have to come to a full stop for 10 seconds after it's warmed up to get into Stage 4 (full hybrid) operation. If traffic conditions do not permit this, you can drive forever and never achieve maximum efficiency. THIS IS STUPID!!!!!!!
    That's my entire list of complaints. In every other respect this is the coolest, best-designed car in the universe.
  11. nstevens
    nstevens Junior Member
    31
    St Paul, Minnesota
    I agree with Daniel on most of those points, especially with the default to outside air.
    One observation ... when I initially bought my car, the heater was definitely not working well. I had on max high blast in 10 F weather and it was not even keeping the car warm. Being the lazy guy that I am, I waited before bringing it in to the dealer. After another week, I noticed it got better. After 2 weeks of high usage, the car was blasting very hot air with no problem and I've never had a problem since. Is there something that needs to be 'worn-in' on the heater???
  12. Tideland Prius
    16,445
    Daniel, you know you can have it in auto mode without A/C right?
  13. daniel
    14,487
    1,519
    Spokane, WA
    Yeah, but I still don't like its choices, especially its insistence on outside air when the car is cold. Give me old-fashioned hand controls any day!
  14. Frank Hudon
    Frank Hudon Senior Member
    4,147
    another reason I like the Classic Climate control is done with 3 dials on the dash. Don't think I've touched it in 3 months. 21C feet and window fan on low and I dont' want recerc. so that's just fine and a/c is another button. Do it by braile when driving.
  15. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    My 2005 BC 6 purchased in the end of March doesn't reset to outside air. It stays where I used it last, which is usually recirc. Is this settable?
  16. BrianTheDog
    BrianTheDog New Member
    178
    Northeast Alabama
    Works for me!
    So far I've only had to deal with temps in the '30s F with cold start. I just put dash vent fan on high and max the heat, and get toasty in a minute or so. Then back off to keep from sweating.
    I dread it when 'Bama gets hit with the teens, tho.
  17. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Have you *tried* forcing recirc when just starting out cold? You'll
    completely fog the windshield in about 2 minutes, especially with
    more people in the car than just the driver.
    _H*
  18. Tideland Prius
    16,445
    Hmm, how come you guys use MAX HOT? Like Frank, I just leave it at 21 and it's quite toasty at 0°C.
