Prius homepage has been redesigned; NiMH batteries again?
Discussion in 'Gen 3 Prius Main Forum' started by chughes123, Feb 11, 2013.
  1. chughes123
    chughes123 Junior Member
    66
    vancouver washington
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Only the PiP uses lithium ion. The lift back has and continues to use NiMh. What made you believe the lift back had or will be using LiIon and that it was a typo?
  4. Mike500
    Mike500 Senior Member
    2,593
    764
    Given the current problems with Lithium Ion batteries on the Boeing 787, Toyota has stayed the tried and true Nichel Metal Hydride battery system on most all Prius models except the PIP, were weight would be an issue due to the large number of cells required.
    When used in the proper manner and charged and discharged correctly, the NIMH batteries have a long service life. Weight saving on the smaller size of the hybrid batery would be less of a factor than the larger batter on a PIP or pure electric vehicle.
  5. chughes123
    66
    I thought all 3rd gen Pri had Lithium ion batteries, except for the C and V. Whoops, guess I am wrong. I remember reading all these articles on the internet in 2009 that the new regular 2010 3rd gen Prius would have a Lithium ion traction battery but now everything points to NiMH. Hmm, so no Prius models in the US use Lithium batteries except for the plug-in.
    Why the 2010 Toyota Prius Doesn't Have a Lithium-Ion Battery
