Prius HV battery charger-help needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by meirzitun, Jul 15, 2020.
  1. meirzitun
    meirzitun Junior Member
    IL
    Hi guys.
    Im living in istael and i want to built a very good charer for Hv bat..i am also want that charger will abale also to check the HV battery to tell which cell is bad to recondition the battery at good way..somebody have which component i need..all component need to be 220 ac volatge..
    Thank you about your help!!!
    49,445
    welcome!
    you can search here for threads on battery rebuilding. many different chargers are covered.
    an app like dr. prius can give you cell data
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    I think you are in way, WAY over your head.
    If you have to ask........you are WAY under-qualified for this kind of project.
