Prius HV battery module testing and matching
Discussion in 'Gen 2 Prius Main Forum' started by Xavier75, Mar 7, 2018.
  1. Xavier75
    Xavier75 Junior Member
    Has anybody seen these videos?
    I'm wondering if there is a way I can graph the same data without using expensive and complicated equipment. It seems that their method is good for identifying bad modules and figuring out if a replacement module is a good match. Meaning that the replacement would have similar internal resistance, capacity, charge and discharge rate. I would like to graph data on the replacement module that I purchased compared the existing ones. Has anybody done this maybe with Audrino Pic board setup?
  2. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    You can graph on tech stream too.
  3. Xavier75
    Techstream would probably be great but I need something where the HV battery is out of the car already so I can check if replacement module is a good match.
