Prius ICE won't turn on. Limp mode.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Clytnjms, Feb 6, 2025.
  1. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    Hello I put some cataclean in the gas tank because my catalytic converter is getting worse. I was hoping I could buy some time to replace it which in hindsight I won't ever do again.
    So my Prius the past couple days has been driving like the Cat was clogged prior to me doing this. It'd lose power Going uphill and have a sound like a paper plate into a box fan flapping sound when I tried accelerating. It could still get to normal speeds it'd just have that tapping sound which fit evey online description of what a clogged Cat does and I have both codes for my catalytic converter.
    I realize this was all A HUGE mistake and if I could go back in time I would but that doesn't help me now.
    So while driving i suddenly lost power and it went into limp mode. I'd usually always drive fast enough to where that sound wouldn't present itself but was hoping the cataclean would do its job so drove at normal speeds while I was beginning to go uphill.
    I realize this was all a huge mistake now so please don't lecture Me. I just REALLY need help now because it won't go into drive.
    I have error codes P0456. P3190. POA4B. P0401. P0420
    The only error code I had was A red steering wheel with an exclamation point and the check engine yellow symbol which I've had periodically since I owned it because of the catalytic converter code.
    I've unplugged and plugged it in several times and have never changed the 12 volt battery so I believe that is drained too now because its acting like it's possessed. It'll make a whirring sound when I try shutting it off and the yesterday when I connected the battery terminal back In it immediately turned on like I had just pressed the power button. When I'd press the brake pedal it'd flash all kinds of codes and would intermittently go in and out like a dead battery would. So I believe the battery was already low but me trying to troubleshoot it drained it completely.
    It's an absolute nightmare and I've been using the car to make money and now I'm completely screwed if I don't get it going.
    Any help would be beyond appreciated and trust me if this ever happened again I'd change the Cat immediately
  2. 6cylinderbike
    6cylinderbike Junior Member
    Hendersonville Tn
    If it was mine, I would charge the 12v battery, and disconnect the mass air flow sensor, and see if it will start. Warning - I'm just a shade tree mechanic, but with years of experience. Even if it does start, based on the symptoms and codes, my guess is that there will probably be a lot of work to do.
    BiomedO1 likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    The first problem is a discharged 12V battery.
    Either charge it or replace it.
    The second problem is that after a series of unsuccessful starts, the high-voltage battery also discharges and will not be able to do anything without recharging.
    The third problem is that the engine exhaust system may not work due to a melted and clogged catalyst. This requires diagnostics and inspection with partial disassembly.
    Mendel Leisk and Grit like this.
  4. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    By charge you mean jump start correct? It's worth a shot. I'll try it. I've hooked jumper cables up to the area in the fuse box and it worked. First time I ever jump started It ever.
    Oh the Cat is definitely shot so was hoping to clean it. I'm concerned that red steering wheel and exclamation point could mean fuel related issue because from what I read that dashboard light can indicate issue with fuel too. And I've ran cataclean and seafoam through the gas tank within the last couple months several times. Not at the Same time but several.
  5. bisco
    52,740
    If you jump start it, you’ll have to leave it ready for a long time or drive around for four hours or more to charge it properly.
    I think he meant put a battery charger on it.
    If it won’t hold the charge, you’ll have to replace it
  6. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    It had no problems holding A charge until it died while in route and went into limp mode. I disconnected and connected battery several times to no avail. That's when the red battery dashboard light came on. I can easily drive for 4 hours without stopping. That's not a problem whatsoever.
    It's the red steering wheel exclamation point dashboard light That's throwing me off and preventing the ICE engine from engaging. That dashboard light can also be related to the fuel pump and fuel filter I've found out from the non stop researching I've done since it happened. Very irritating way to for Toyota to do these things. It'd be much easier if they told me EXACTLY what I need to do instead of deciphering through the multitude of possible options. Craziness
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    What icon are you talking about? It looks like you are confused.
    It could be the handbrake on icon. Can you take a photo?
  8. ChapmanF
    18,919
    To the best of my knowledge, power steering issues don't prevent the engine engaging. Are there no other warning lights on? Has the car been queried by a scan tool that can query all the controllers in a Prius?
    If your non stop researching has been telling you the power steering warning light can also be related to the fuel pump and fuel filter, I'm afraid you need to find better places for researching.
    Toyota Service Information and Where To Find It | PriusChat
    By the way, the warning light picture and description I used above are from the "If a warning light turns on or a warning buzzer sounds..." section in the owners' manual (in the pink-edged pages toward the back).
    ThePrius11 and MAX2 like this.
  9. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    I'm not confused by anything. The dashlight symbols I have are the red steering wheel with exclamation point and the check engine light
  10. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    There aren't any warning lights. How its related to the gas tank inadvertently was something I found on the internet. I'll post what I read.
    #10 Clytnjms, Feb 11, 2025
  11. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    I meant there aren't any warning sounds not warning dashboard lights. My apologies. There aren't any warning sounds. There is the red steering wheel with exclamation point. Check engine light. And check hybrid system. ICE won't turn on. Had to have it towed home. Been sitting 7 days. I live 50 miles from the city. To say this hasn't been an absolute nightmare is an understatement.
    I have 7 error codes related that I've researched thoroughly. I'll list them
  12. Brian1954
    Brian1954 Senior Member
    2,644
    1,052
    South Central PA, USA
    You stated "And check hybrid system". Please clarify if this was a written message on the dash.
    Do you have the Red Triangle (Master Warning Light) on the dash?
    What scanner are you using to check for trouble codes? Be specific with the manufacturer and model number.
    You stated that you have "7 error codes". I only see five of them listed. What are the other two codes that you have not listed yet?
    Grit likes this.
  13. ChapmanF
    18,919
    Ok, so if I might make this easier by putting the information in one place, you have three visual dash warnings:
    • Check hybrid system (because of the P0A4B)
    • Check engine (P0401, P0420, P0456, P3190)
    • Power steering (codes TBD)
    You say you have seven trouble codes, but in your attachment in #11 I see only five: P0401, P0420, P0456, P3190, and P0A4B. Did your screenshot not include the other two? What are they?
    It's helpful to put the codes into the text of your post (as here) and not just in a picture attachment: other people can then find your thread when they search on those codes.
    I would focus first on the cause of the Check Hybrid System warning: the P0A4B code. When the controller is unable to read the position of the "generator" (MG1) rotor, it is unable to control MG1's rotation, and therefore unable to crank the engine.
    Once that is taken care of, you'll be able to crank the engine, but may still face the P3190 issue that the engine doesn't start. That will require some diagnosis of its own.
    The remaining engine codes can be attended to later once you get the engine to start. They reflect separate issues (one with the EGR system, one with the catalytic converter, one with a fuel vapor system leak) that probably haven't all shown up at the same instant; this looks more like a car where some different issues have been unattended to over some time.
    Your list of five codes didn't include any from the power steering system, but clearly it's the P0A4B and the P3190 that deserve top billing for now, and a scan tool that can retrieve the steering codes can be a matter for another day.
  14. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    I PROMISE you if I had the red triangle of death I'd had mentioned it in at least one of the numerous posts I've posted so far. It's a little perplexing how dumb You must think people are. Why anyone on planet earth wouldn't mention the worst dashboard lights that exists is beyond me.
    I've used several scanners. They all say the same thing.
    And my apologies it mentions the code for the catalytic converter more then once. Same code but multiple times. The P0401 code if I remember correctly. It lists two of the codes twice. If it's that significant I'll go hook up to it and find out which ones it lists twice. Both of them had to do with the Cat which I've known was bad and used to smell melting but after everything I read on the internet assumed it'd be thousands of dollars. I found A shop up the street thats going to do it for hundreds not thousands and the part wasn't expensive at all after I researched it for awhile.
    I'd just have changed it immediately if not for the majority of idiots online saying its be a 3-4 thousand dollar job. I'm getting it done for a small fraction of that. Lesson learned. Do your own diagnostics and research!!
    I've listed the exact dashboard messages that there are. It's almost insulting to insinuate that im that incompetent to list exactly what i see. I can see what dashboard warning codes are listed. The red triangle of death looks nothing like A red steering wheel and exclamation point. I have two perfectly healthy eyes that can see without problem
  15. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    It has 7 but lists the same one twice. Both related to the cat and exhaust system. I believe it's the p0401. If it's that crucial I'll go hook it up again and tell you which ones are listed twice.
    And thank you. I've been trying to tell people that I think thats the error code that is preventing the ICE from engaging. But everyone else seemed to think I just needed a new battery or something else very minor of the sort.
    I had a front end collision with a highway sign 5 or 6 months ago. It messed up the front bumper and left a very small dent In the hood. I havent ran a scan since then because I didn't own one then and I drove away from the situation just fine.
    I lost control and served and ended up on the side of the road In the Nevada desert. I'm an animal lover and A coyote darted right in front of me while I was going 70 mph. I did a 360 took out a highway sign and ended up way off the side of the road on in the Nevada desert surrounded by Joshua trees. I drove away fine but did change the bumper. I do wish I'd had scanned now obviously because I don't know if that code has been there since then or not. That was 8 months ago. I lost my tail lights last month and whenever I change the fuse after changing the bulb the fuse immediately blows. If it's the transaxle generator then I'm wasting everyone's time because I'm for sure not getting that fixed. If replacing that is what it's going to take to get the car to drive again then that car isn't going to get fixed.
  16. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
  17. ChapmanF
    18,919
    Ok, so you have five DTCs, the ones listed above, and a couple of them were reported more than once. It's not that significant, just from here we can't tell if you meant to list seven codes and two got left out by mistake, or how significant they were. Thanks for clearing it up.
    The "check hybrid system" MID message is generally redundant with the master warning triangle, and you do have a hybrid system code, P0A4B, which would be expected to light it. Brian asked a reasonable question. There may be some reason the triangle didn't light in your car, but among the concerns you've got, that can be left for a way later day.
    As you've confirmed the codes you have are the ones in #13, the advice there stands. Find and fix the P0A4B so the car can spin MG1 and crank the engine. Then if the engine cranks but won't catch (P3190), find and fix the cause of that. The other codes are small potatoes by comparison. (P0420 is the catalyst code. P0401 is low EGR flow, and may attract a post from Mendel about following that up.)
    I hope you can make some headway with the above.
  18. ChapmanF
    18,919
    The code is about inability to read the generator's rotor position. The wiring to the position resolver is in roughly the area of your collision damage. Go look. Wires may have been damaged but still functional 6 months ago, and later failed.
    Use the trouble codes' troubleshooting steps to look at the simple causes before assuming the worst.
    #18 ChapmanF, Feb 11, 2025
  19. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    I'm most definitely guilty of assuming the worst. 100 percent guilty as charged
  20. Clytnjms
    Clytnjms New Member
    24
    Las Vegas
    My apologies yes its written on the dash. The scanner I bought I also downloaded an app and it gives Me even more info sort of but not really. It lists the same error codes as the scanner
