Prius idle high after cleaning throttle body
Discussion in 'Gen 2 Prius Main Forum' started by walleye seeker, Mar 22, 2012.
  1. walleye seeker
    walleye seeker Junior Member
    muskegon
    I cleaned my daughters throttle body on her 2005 prius .
    sprayed it down on the vehicle trying to fix my P0505 code and now its idling high
    is there a learn procedure to reset this after service.
  2. Patrick Wong
    18,200
    6,493
    Check to see if there are any air leaks below the throttle plate assembly, for example a loose PCV hose, a loose or missing engine oil cap or engine oil dipstick, etc.
    Did you contaminate the mass air flow sensor with throttle body cleaning fluid? If yes, then you'll need to remove the MAF sensor and use MAF cleaner spray to clean that part.
  3. walleye seeker
    muskegon
    I pulled the filter box off so no i didnt contaminate the maf . but i was going to clean that next .
    i actually put a hose clamp on the pcv hose a few days ago thinking a vacuum leak was my problem for my p0505 code . But no dice light came on again which led me to throttle bottle cleaning.
    I just thought i read something about doing a learn procedure for idle speed after performing throttle bottle cleaning but i cant find it .
  4. Patrick Wong
    18,200
    6,493
    You could also try disconnecting the 12V battery negative cable where it bolts to the body of the car for several minutes, to give the engine ECU (and all others) a chance to power down and reset.
    I am not aware of a specific maintenance procedure that would allow you to adjust idle speed.
    kenoarto likes this.
  5. walleye seeker
    muskegon
    I pulled the negative cable for about ten minutes and it worked purring like a kitten again
    kenoarto and Sezy like this.
  6. walquis
    walquis New Member
    Lisle Illinois
    I had same problem. I thought I'd contaminated the MAF sensor with choke cleaner (should've done more reading!), but when I pulled the battery cable for ten minutes and restarted my Prius, all was well. Whew. Thanks very much, Patrick and walleye seeker!
  7. Sezy
    Sezy Active Member
    431
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Any MPG increase after cleaning? I have a high idle too now. Going to reclean the MAF sensor and reset the battery.
