Prius II Battery
Discussion in 'Gen 2 Prius Main Forum' started by GreenPeopleRock, May 26, 2010.
  1. GreenPeopleRock
    GreenPeopleRock Junior Member
    RI
    I just purchased a 2007 Prius with 47,000 miles on it. This is my first Hybrid so I am new to the charging stuff... I have noticed that the battery charges to green sometimes, but mostly stays in blue and 6 or 7 bars. I can drive home and park the car, with green bars, when I go out in the morning the battery charge is half gone. Is this normal?
    I have also noticed that it does not seam to be getting the milage it is suppose to be getting. First half tank I got 48mpg calculating at the pump... second tank I got 36 had the A/C on sometimes, but would not
    think it would drop 10 MPG.
    49,507
    shouldn't drop that much, give it a few more tankfulls. seeing a lot of newbies with used pri and mileage problems. when you start the car in the morning it should be about the same but may drop quickly during warm up.
  3. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    It is impossible to accurately judge gas mileage on individual fill-ups. The gas tank uses a bladder that makes it impossible to get accurate pump shut-offs. I keep track of both per tank milage as well as the mileage that the MFD shows and find the kind of variations that you encountered - while the MFD display milage is more consistant (on average I find my MFD reads about 2% high).
  4. uart
    uart Senior Member
    4,215
    1,201
    Australia
    No it is not normal to drop a significant amount of SOC (state of charge) overnight. Here I'm assuming that you mean that the charge is gone as soon as you put the car into "ready" mode but before you actually drive it.
    If however you mean that the car drops a few SOC bars soon after you start driving it then yes this is absolutely normal. This occurs because the prius will preferentially use electric power while the engine warms up. Even though the engine is running it's basically just idling while the electric motors do all the real work. So in the first one minute of operation it can use lots of battery power. You can minimize this by either letting it warm up (idle) for 30-50 seconds or by driving very slowly at minimum power for the first 30-50 seconds (with engine running of course).
    This is simply due to the fact that the amount of fuel used is not known accurately enough. You have to measure total miles travelled and total fuel pumpped over several weeks to really get a good "pump calculated" MPG estimate. The reality is that you're probably getting about 40 MPG and on the first caculation you under-estimated the fuel used (I mean actually used as opposed to what was pumped, because you never really know exactly how much is left in the tank) and on the second caculation you over-estimated the fuel used.
  5. GreenPeopleRock
    RI
    Thank you for the response and answers... I have been keeping my eye on the hybrid battery state and it seams to be ok. The mileage seams to be ok as well, my last fill up I got 54.8 mpg.
