Prius II module part number and procedure
Discussion in 'Gen 2 Prius Main Forum' started by Peterhans, Jan 9, 2022.
  1. Peterhans
    Peterhans Junior Member
    103
    Germany
    Greetings, after much troubleshooting and deciding the path on repair, I have decided to change out the module. However, finding the module part number and a good source is a challenge. Also, does anyone have a good procedure on changing out the module? From what I read, one basically tears out the rear to get access to the battery, Then the battery goes on a workbench. I was wondering because of the weight whether the work can be done in place? Any suggestions are appreciated. Btw, I checked a large automotive shop and no signs of hyprid modules. Thanks.
  2. Peterhans
    103
    Germany
    This is for a 2006 Prius
  3. ChapmanF
    18,543
    While it may be possible, there is also the consideration of the serious hazards involved, which may favor working where you will have the greatest visibility and comfort, and be less likely to work in awkward, cramped, or uncomfortable conditions putting your safety at risk.
    Other members have developed simple techniques (no more than, say, a couple of wooden boards and a wheeled cart) for dealing with the weight, in order to get the battery to where it can be worked on in comfort and safety.
    Peterhans likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,055
    5,304
    Pacific Northwest, USA
    If you can lift a full size bag of concrete out of the back of the car, you can lift the battery pack out too... As for spare modules, anyone in the EU who sells rebuilt hybrid battery packs can sell you one. Alternatively, but more expensive, my buddy in Oregon, USA ships internationally: https://2ndlifebattery.com/about-us/
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    Toyota sells only complete HV batteries (or for some models, battery stack sub-assemblies); there is no Toyota service part number for an individual battery module. As far as I know, Toyota’s NiMH battery supplier (Primearth EV Energy) doesn’t sell new modules on the open market, either, which implies that any modules you might find for sale are used (but perhaps tested and selected) or from another source.
  6. Peterhans
    103
    Germany
    Found an assembly number for the battery module B0160BEIJ6. Found this number on Amazon for Panasonic/Toyota. Problem finding the part. Also, found a video where the work was done in place. Search enough videos and can find what one likes.
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    That’s Amazon’s number (ASIN) for a listing from a third-party seller, which describes the item condition as “Used.” Like many others, this seller is offering used modules salvaged from batteries that were replaced, not new modules from Toyota or another source.
  8. Tombukt2
    Tombukt2 Senior Member
    13,408
    2,415
    Durham NC
    True just remember you will bent over the batch of car a few hours .many stop and stretches on work bench goes much faster snatch jerk n drop on bench be at height etc . I'm 70 so over extending is getting no fun
  9. Peterhans
    103
    Germany
    I thought this was a generic number from ASIN. Have not found a good number nor a new part.
  10. Peterhans
    103
    Germany
    True and keeping this option open.
  11. Tombukt2
    13,408
    2,415
    Durham NC
    Looking at my own nine right now staring in the trunk and when the battery cover is off no problem with the battery sitting in place with the modifications I made to the side brackets the wear it now sits it will be cumbersome and best to undo the back row of bus bar nuts so I think I'd rather at least slide it forward at minimum and bench it if I'm going to be disassembling the whole pack or unracking the cells
  12. Peterhans
    103
    Germany
    Thanks. Are you able to see any part number on the module? According to my test, I have a bank 9 failure. I would remove the bus bars and take voltage tests. I was planning on ordering 2 modules in advance and then do the work. I am surprised that Toyota Ansbach did not have a part number for the module. Thanks if you can get me the part number.
  13. Tombukt2
    13,408
    2,415
    Durham NC
    I will try to go out and crack a rack of sales this afternoon I've got a big delivery coming in a couple things going on but as I remember it I don't think there's any parts on the silver of the batteries I swear I don't or if there is they they get so they get so weak being together that the stamping ink goes funky or something you can't see it but I will take a look and I'll take pictures of what I have I've got at least two batteries here gen 3 and 2
  14. Peterhans
    103
    Germany
    This is super and thanks.
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    There is NO part number on a module that you can use as identification to order a 'new' part.
    Every module has a serial number etched on the top, from which you can decode the manufacture date.
    Certainly, you have ebay or craigslist or some such website in Germany where you can purchase individual tested modules?
    I have well over a thousand, of various manufacture dates, sitting on the shelf in my shop area.
    I did a search on ebay Germany and it came up with these....looks like you can get them easily. Click the link and scroll down a bit. Looks like 59 or 79 euros per module. A bit pricey, but it is what it is.
    https://www.ebay.de/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=prius+hv+battery&_sacat=0
    The last thing you want to do is install a NEW module into your old battery pack. You'd likely be coding out all the time. I call it the Lebron James effect....read this thread post:
    Inconsistent Hybrid battery readings | PriusChat
    #15 TMR-JWAP, Jan 11, 2022
  16. Tombukt2
    13,408
    2,415
    Durham NC
    This is why I just bought a new battery and now I have a few spares if I want to take a spare and fiddle fart around with it and play games cool use that in a car I get for near nothing see what happens no love lost but in my daily driver that I need we're just going to put the battery just like a flashlight new Duracell D's fo of them in the mag light
  17. Peterhans
    103
    Germany
  18. Peterhans
    103
    Germany
    Excellent response and thanks
  19. Peterhans
    103
    Germany
    Looks like I will be going the refurbished and tested route. Will also check and clean the battery fan.
  20. Tombukt2
    13,408
    2,415
    Durham NC
    Battery fan plug service and move over. wrap on zip tape.
